Question about Aspire Digital AD-8091 DVD Recorder
Image has red hue when connected via Composite cables...
All the cables are plugged in correctly and the picture has a red hue. Looks normal when switched to s-video or compontent cable.
  • 4 Answers
Hell, the firest thing you should try and do is to clean all the connections with sandpaper-especially the connections which are on the TV. Good Luck!
Posted on Oct 08, 2007
SOURCE:
TH-50PX77U inputs
Many times a computer's post screens will not show up a TV set, and once the computer itself has loaded the drivers and settings, the set may need to be shut off and turned back on for the HDNI or PC signal to be detected.
It is also possible the settings you selected for display properties cannot be displayed on the TV.
As far as the component video signal, are the connections correct? Sometimes people mistake the composite red, white and yellow for the composite system that divides the red, blue and green video signals.
While also possible, but rare- there may be poorly soldered connections on the "A&D" board (logic board) .
Jul 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Connect ps3 to a non HD tv and picture only black and white?
Are you connecting it to a new SD tv after having been connected to an HD set? You can force the system to reset the video resolution settings by pressing and holding the On/Off button after the system has already turned on. I believe it is ~5-10sec. You will hear another beep after the initial startup beep. This will reset video setting to default and go through the resolution setup wizard again.
However, it is also possible that you are trying to connect a component cable to a composite tv. They are VERY different signals even though the cables fit interchangeably. If you use the Green component cable for video on a composite tv you will only see a grayscale image of the picture. This is most likely your issue. If this is the case you will need to buy a composite cable for the PS3 (the PS2 one is the exact same as the PS3 one.)
FYI Component cable has Red, Green, & Blue cables. Composite has Yellow (Video), White (Left Audio), Red (Right Audio). Both are normal RCA type plugs and will fit in each others plugs, but the signals are VERY different.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Picture is red
If you are running component video, make sure the blue is plugged in and in the right spot. Component video works like this: the green is a black and white image, the red and blue are cover overlays to make the image display properly. So if everything looks plugged in right, then try plugging in a composite video (Yellow) or S-video cable switching to the appropriate input, and see if the image is still red. If so, go to the set up and set the set to factory defaults, and see if that fixes the color issue, It's possible that the color settings on the TV are messed up, with the S-video plugged in go through the set up menu and see if you can correct the color issue IF THE IMAGE IS STILL RED WITH THE S-VIDEO OR COMPOSITE VIDEO, otherwise the issue is a problem with the component video cable.
Oct 01, 2009 | Philips 60P8342 60" Rear Projection...
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Hooking up Coby Csp-94 Speaker to HDTV "no directions"
The green, black and beige cable is non-standard and proprietary meaning that Coby has defined their purpose which hopefully is described in your user guide. It would be worth a few dollars to buy the properly color-coded cables to uncomplicate your setup. Buy cables (or cable sets) that have the same color coding as your TV jacks along with the cable suggested below.
There are several ways to connect to an HDTV system and these are normally standard as previously described.
The red and white are for right and left channels and it isn't uncommon to see a three cnductor cable with one not connected since one of the methods of connection is to supply audio via two cables, video (composite) via a 3rd which is plugged into a corresponding jack, normally colored yellow. Audio cables aren't really required to carry the mix of much higher frequencies of composite video.
If you have the following connectors, try this:
- S-Video (this does not contain any audio information and requires an S-Video cable) - Right (red) and left (white) audio paths.    The S-Video connection provides a better signal that gives you a noticeably sharper picture. This setup is selected from the TV's input source menu.
Sep 07, 2008 | Coby CSP-94 Speaker
Poor picture quality on my samsung HD TV
Hey xf1racer,
Based on the description that you provided, it sounds like you are using a bundled composite video cable to connect your cable box and TV. Composite video cables generally consist of three color-coded cables: one yellow, one red and one white. While the yellow cable is typically used to transmit the video signal to your TV, the red and white cables transmit the right and left audio channels respectively.
Red/green/blue bundled cables however, are often referred to as component video cables - each of the three colored cables is used to transmit a different portion of the same video image from one device to another, and require a second separate cable (typically red/white) to transmit an audio signal.
The primary benefit of using component over composite cabling is that many users may report a cleaner, more brilliant image on their TV as a result. Please keep in mind however that this is not a guarantee that changing from your current set-up to component cables will improve the picture quality on your TV, as picture quality is often based as much on personal preference as it is the actual configuration and settings of the equipment used.
Additionally, many retailers may suggest changing your current configuration to one using HDMI cables instead to improve picture quality even further. Unlike composite and component cables, standard coaxial cables, and S-Video cables which transmit analog signals, HDMI cables are designed to instead transmit uncompressed digital signals. This typically means that more information is available for your TV to process in terms of color hue, color intensity, as well as image resolution. Again, remember that any perceived improvements will be based on both personal preference as well as your home theater configuration.
Should you have any questions or lingering doubts, I would strongly suggest speaking with a Magnolia Home Theater agent at your local Best Buy™ store for more information. Most stores will have similar TV's on display using more than one type of connection, and sales associates are always able to provide additional suggestions if desired.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 10, 2008 | Samsung PCL545R 54" Rear Projection...
Aspire Digital AD-8091 DVD Recorder Logo
48 people viewed this question
Top Aspire Digital Televison & Video Experts
Ekse
Are you an Aspire Digital Televison and Video Expert? Answer questions, earn points and help others
