Distorted sound from teac a r650 amp - Audio Players & Recorders
  • Flaviano Tordesillas
    Flaviano Tordesillas Nov 20, 2013
    Distorted sound coming from the left channel, the right is ok.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
Switch cables on the channels, check for leaky cap and transistors
Posted on Dec 30, 2013
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
Tascam 122 Mk III - input signal is low and distorted
It is hard to guess what is causing this but for all of the gain to be reduced like that either the deck has seen some really high input signal in the past that blew out some amplifiers or that there is a power supply component that has taken the input electronics down.
I suspect that you will need to have a Technician look at it. If you are near Chicago, I may be your answer, I have been working with these Teac units for 40 years and was a Lead Tech at Chicago Factory Service in Arlington Heights.
I can be reached at skywavebe@sbcglobal.net
If you are far off- I have other people that can do the job one in New Jersey and a few others.
Aug 14, 2012 | Tascam Audio Players & Recorders
How to upload sound files from Teac external floppy
click start all programs accessories open windows explorer
from there you select the 3 1/2 floppy right click select the data right click copy navigate back to the destination drive right click select paste
????????????????????????? ?hope this helps
Dec 21, 2010 | Teac (C87347) External Floppy Drive
There is very low sound from turntable to teac
Check out if the earth connections are are good in the jack.
Are you connecting to a dedicated socket for turntables on your amp? Turntables have to have a pre-amp stage (unlike CD/Tape) before they go to the main pre-amp. If the Teac doesn't have a turntable socket, you will need to buy a pre-amp for the turntable.
Jan 20, 2010 | Audio Players & Recorders
How to hook it up to a amplifier
sound source out(dvd-cd player)-------------to teac eqa-5 in-----------------teac out---------to amp line in.
Oct 31, 2009 | Teac EQA-120 Home Equalizer
Have bought ipod nano 5th generation and find the sound is distorted when using my teac cx-225idab docking system. older version of ipod is fine. any clues.I thought it was the ipod and had it exchanged...
Usually, that will happen if the ipod is not compatible w/ the docking station. Try to connect the ipod to a different docking station to check if it will gonna do the same thing...
Oct 26, 2009 | Teac CD-X10i Docking Station for Apple...
Distorted sound, from any of the inputs
All inputs are switched and go through a series of amplification stages. If the volume appears to change correctly, but hte sound is just distorted independent of the voluem, then the problem is likely to be in the beginning stages of the amp. This can be as simple as a defective OpAmp IC or diff-amp section or even a voltage regulator failure. Without the exact model number and some internal measurements, I can not say for sure. Can you supply more details?
Thanks,
Dan
Oct 13, 2009 | Teac Audio Players & Recorders
Hum in TEAC EX-M3 radio
(1) Is the hum out of both speakers?? (2) Is the sound distorted out of any of the speakers?? If the answer is yes to 1 and no to 2 then it sounds like one of the smoothing blocks or capacitors have gone down and requires replacement. If no to 1 then you probably have blown the output chip or taken one side of it out, check all connections to the speakers, try not to use tape joints which are unreliable. If you do have to piece the cable, solder the connections. Then replace the chip, Ian
Aug 13, 2009 | Teac EX-M3 CD Shelf System
Audio cartridge
What cartridge are you asking about? The phono, or what?
Mar 28, 2007 | Teac DC-D2831 CD Shelf System
65 people viewed this question
 Grubhead
Grubhead
