Question about Classic Hammonds Leslie 22H Component Kit - Amps without 5U4 Rectifier Tube
Roar in electric organ when turned on - Classic Hammonds Leslie 22H Component Kit - Amps without 5U4 Rectifier Tube
My dryer makes a loud roaring sound then eventually stops and wont turn back on until it cools down
you lent vent may be clogged but I don't know much about driers sorry
Nov 12, 2013 | Dryers
Chrysler town country noise
Your cars engine "roars" or the fan motor "roars"? If its the engine, does your car have tachometer and what are the rpms?
Oct 16, 2013 | Cars & Trucks
Engine roaring above 30mph
Is it possible you are hearing a wheel bearing instead of the engine or exhaust ?
Normally a bearing will roar on a turn and not on a straight stretch, but I guess its possible to do it the other way. A tire will make a roaring noise too.
I can't think of anything related to the engine that would roar only on a turn except maybe the power steering.
Feb 19, 2013 | 2006 Mazda 6 s
Kenmore dryer makes roaring oise when the drum turns
I have the same problem. I thought originally it was the seal around the drum but we pinpointed it to the fan motor. We think there is something wrapped around the fan motor or the bearings is going out.We would have to take everything out the drum and belt and motor to get to the problem. If you take the back panel off and take the lint trap off you can turn the fan and you can hear the loud noise. We tried spraying wd-40 around the fan pin but don't get any on the motor. It will burn it up if you do that. But it didn't work so you will have to take everything out.
Feb 01, 2009 | Kenmore 62602 Electric Dryer
Roaring Sound During Operation of Dryer
Does the roaring sound occur after the machine warms up? If so, it could be a bad drum bearing. the heat from the dryer causes it to expand in its housing and, since it may been defective, could start "roaring". If so, The dryer drum shaft/bearing assembly will need to be replaced
If however, the roaring is immediate upon start up then u may have a bearing in your dryer motor. The entire motor may have to be replaced.
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
Classic Hammonds Leslie 22H Component Kit - Amps without 5U4 Rectifier Tube Logo
18 people viewed this question
Top Classic Hammonds Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Classic Hammonds Audio Player and Recorder Expert? Answer questions, earn points and help others
