Question about Epson Stylus Photo PX650 Multifunction printer / copier / scann
Px650 not printing full page, cutting print area on right
Print area bigger than A4, not printing full page cutting off right hand side so missing print, If i print a receipt out it only prints 3/4 of the width of the receipt
    New Friend:
  • 14 Answers
You can maintenance ................. cleaning or deep claening ......click
it is in page set up ................. main........ preferences...
Posted on Nov 18, 2013
Testimonial: "I have tried deep cleaning and resetting but it is still the same, five years old but not really worked hard, no errors showing, a bit noisy when printing, So still at a loss as to what it is that is wrong with it."
5 Suggested Answers
websnail
  • 419 Answers
SOURCE: Print out is misaligned - but only in one small area
It's more likely to be some dirt or soiling on the calibration strip which runs along the back of the printer and through the back of the printhead..
Look for a bit of clear plastic which has lots of little black lines on it... this is the calibration strip... Chances are you'll find a little dust or ink on it...
Whatever you do, DO NOT pull on this... Just gently clean it with some tissue and a lint free cloth but make sure you don't dislodge it.
Posted on Jan 29, 2009
SOURCE: white vertical line in image printing
how can we take all fax sent and received print from hp 3050 printer.
Posted on Apr 01, 2009
SOURCE: Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Posted on May 11, 2009
diddydaveh
  • 154 Answers
SOURCE: black solid line on the right hand of page when
Hi, remove the black drum and clean the corona wites and drum GENTLY with a LINT FREE CLOTH. If there uis no change in the print quality you may need to replace the black drum. Hope this helps
Posted on Feb 22, 2010
Epson PX650 not printing the full A4 page of my receipts, cutting off on right hand side
COULD BE THAT THE PAPER IS BIGGER SIZE THEREFORE CUTTING.NEED TO SAY FIT TO PAGE ON YOUR PRINTER DRIVER
Nov 18, 2013 | Epson Aculaser C1100 Printer
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
When trying to print Avery Labels L7160 the top few labels print within each label 'frame' BUT towards the end of the page the labels are printed further up and therefore are out of the label 'frames' ALSO...
For Word 2007/Word 2010
1- Click on the Office button
2- Select Print then Print again.
3- In the Zoom section make sure 'Scale to paper size' is set to 'A4'
4- Click on the Properties button.
5- Click on the Paper / Quality tab, then click on Advanced.
6- In the Paper/ Output section it has Paper size. To the right you have a drop down menu . Make sure A4 is selected and not letter, then click on OK.
3- There may also be other options in your printing preferences such as 'Print Area', 'Scale to Fit Page Size' or 'Page Margins. These will all need to be set correctly for your design to print 100% e.g. Print Area set to Maximum, Scale to fit Page Size disabled and Page Margins set to Minimized.
Some printers ( for example Epson printers ) have a 'Reduce /Enlarge' facility that defaults to 94% or 97% (instead of 100%). To set this to 100% click the 'Layout' tab and in the 'Reduce/Enlarge' section select 'Custom' you should then be able to change the scaling to 100%.
Mar 12, 2010 | HP LaserJet 3050 All-In-One Printer
Bulk mail inde
Put spaces in your type to move it over if you cannot move the margins. You might also be able in print options page setup to indent the margins or paragraph so it prints inside the page.
Aug 31, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Sheet feeder wheel marks on both sides of A4 photo prints
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost. no need to switch over to any other brand.trust me Kodak is really good.
Jun 22, 2009 | Kodak ESP 5 Printer
Printing
Some net printouts need to be printed in Lanscape mode. For example I just selected Print Preview on this page and some of the right side is missing. You can use page setup to select landscape.
Hope that helps...
Geno
Mar 10, 2008 | HP PSC 1410 All-In-One InkJet Printer
Epson rx420 printer
Another post suggests that you printer is dead -see (http://www.fixya.com/support/t354202-epsom_rx_425_just_prints_half_page) but I've had the same problem - things seem to be ok after I reset to the defaults in the main page of the printing preferences.
Mar 03, 2008 | Epson Stylus RX425 Multifunction...
Epson Rx420
Click Start - Printers and faxes
Right click on the printer icon and select properties.
Click on Advanced tab. Enable the option print directly to printer.
Click apply n OK.
Check for the result.
Dec 22, 2007 | Epson Stylus 1400 InkJet Photo Printer
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
Epson Stylus Photo PX650 Multifunction printer / copier / scann Logo
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
