Question about Symbol LS3408 Barcode Scanner
Windows 7 driver ESKY USB AUTOMATIC BARCODE SCANNER
4 Suggested Answers
thesuperdude
  • 97 Answers
SOURCE: LS 1902 AND USB CONNECTION
Scan the Set all defaults barcode from the product reference guide and set the scanner to use USB again if required. This should sort out your problem.
Posted on Mar 26, 2009
  • 597 Answers
SOURCE: No PS/2 Ports on new PC only USB ports. Need to make work with USB connectivity.
I have a P/S 2 port to USB adapter that I got with a microsoft natural keyboard once. So I know they make them. Here are a few you can get.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=ps2+adapter
Posted on Jun 02, 2009
  • 38 Answers
SOURCE: LS4004 Scanner displaying 2 random digits on scan?
Hello coreyog. I think I can help you with at least part of this. The "suffixing with an enter" you're describing is called a Carriage Return. If you go to your manual, you'll be able to find the Carriage Return enable and disable barcodes. Disabling the Carriage Return should fix that part at least.
As far as the digits not found in the barcode, there are about a thousand and one reasons it could be doing this. Generally, I suggest to my clients that they use the manual to reset the defaults of the scanner while plugged in to the problematic machine, after resetting, unplug the scanner and plug it back in. This should get windows to re-discover the device, as it were. This takes care of it about 75% of the time. I hope I've at least helped you get a start on fixing your scanner foibles. Good luck!
Posted on Jan 07, 2010
4600g
Basically you don't need any driver for USB interface,but will take longer time to auto install the driver on certain version of Windows 7.
Jan 08, 2014 | Honeywell 4600g Wired Wand Barcode Scanner
Tip
How to connect a barcode scanner to your computer
<p>If you run a business, you probably need a barcode scanner to help control the items in and out of your iTunes. It is also possible to bar code reader to a computer at home. These devices connect through a USB port like most other external hardware. <br /> <p><br /> <p>1. Connect the barcode scanner to your computer via the USB port. A window showing the computer has detected a new piece of hardware. <br /> <p><br /> <p>2. Insert the CD driver installation. Wait until the installation wizard. <br /> <p><br /> <p>3. Follow the instructions to complete the installation. Remove the driver CD and replace it with a software CD is provided. <br />
on Jun 26, 2011 | Computers & Internet
Pc won't recognise scanner after installation I am looking for a free windows 7 driver update. problem is I have 2 usb ports close together and don't have a usb hub...any suggestions
ok, you purchase a 4 /8 port USB first. This is a adiitional device which is insatll through USB port. after that you can get additional 4/8 USB port.
Thanks.
May 13, 2011 | Computers & Internet
Windows 7 cannot detecct my OPN-2001
It seems that this only has drivers for Windows XP, but you can try installing the XP drivers on windows 7.
http://old.opticon.com/uploads/Software/USB%20Drivers%20Installer.exe
Here is the link to download the drivers, make sure the scanner is not plugged in until after the drivers are installed. This may not work, but i have had to do this with other hardware and sometimes it does work.
Feb 28, 2011 | Opticon OPN 2001 Mobile Data Collector...
Need to the USB drivers for my xi2000 hand scanner. I'm going from the old PS2 connector to the USB connector, I'm using a keyboard cable to convert from a PS2 to USB. Do I need the drivers also, to make...
You may not need drivers; try plugging your scanner in after Win boots. If you get a box stating that WIn has 'found' a new device, it may install a basic driver for USB.
Otherwise, check the scanner mfr.'s website for drivers that you may need.
Jan 31, 2011 | POSX POS-X Barcode Scanner Xi2000 USB...
The driver doesn't appear to work with windows 7 64bit. Is there a driver out there for it?
The only driver for this scanner is: OPOS Driver for Symbol Scanners v3.31 located here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12673&sliceId=&dialogID=211054608&stateId=1%200%20211052482
If this driver doesn't work for you and you're using windows 7, install the free virtual XP from Microsoft and run the software in virtual mode.
I do that for a wide range of programs that haven't been supported for windows 7.
Hope this helps,
TinkerMac
Jan 17, 2011 | Zebra MiniScan MS4407 Barcode Scanner
I am searching for a Windows 7 64bit driver for my MS9535 Bluetooth hand scanner
i
this is all drivers i could find -- you will have to contact Honeywell (Metrologic was bought out) to get drivers for Win 7 .. go to this link
http://www.honeywellaidc.com/en-US/Downloads/Software/Pages/default.aspx?pid=9535
if it doesnt help , please do not rate my service
Dec 09, 2010 | Metrologic Instruments MS9535 VoyagerBT...
HHP Handheld IT3800lr-12 - i can't configure it to USB
If you have the manual, try to cofigure it to USB Keyboard and/or to LAPTOP DIRECT CONNECT. This last option is on page 1-7 in the manual I have with me. Please let me know if it works... Good luck!
Dec 15, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
CIPHERLAB 1000 (serial ) Driver for WinXP
you dont`t have a driver for serial comm.open hyper terminal on com port where is the scaner.read a code and you wilkl see the numbers on the screen.If you want to work with some windows programs change that barcode for usb or ps/2 variant.
Jan 15, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Symbol LS3408 Barcode Scanner Logo
113 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
