Question about Lanzar Vibe 218 Car Audio Amplifier
Pb1644 my amp has a protect light on that won't go off. no sound nothing...what do I do....
  • 631 Answers
Disconnect all speaker wires and signal cables from the amp. If it powers up (no protect light), the wiring needs to be checked. If it still shuts down (goes into protect), the amp likely has blown output transistors.
Posted on Oct 09, 2007
SOURCE:
Left headlight
If the other head light works ,it won't be a fuse
Check every fuse in the car,won't take long &
the fuses will protect a complete circuit,not just
a couple head lights.
The light switch has a circuit breaker not a fuse.
Have you removed & tested the lamp it'self
No owners manual? Need that for fuses & bulbs/lamps
Sep 04, 2012 | 2001 Hyundai Sonata
My amp protection light came on one day. Now it won't turn on. What's wrong?
There is more than likely an issue with your amp, it could've happened from a wire being shorted to ground or a damaged sub causing bizarre impedance issues at your amp. Uninstal it and have it bench tested.
Jun 03, 2012 | Rockford Fosgate Power T1000-4 Amplifier
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
Protection light flashes on and i get nothing
Hello shwoop22,
It sounds like power is shorting out or the amp is defective. With the fuse removed, use a multimeter set to ohms and check between the power terminal to ground.
The protection light will normally come on if the amp overheats (for example when running with too low impedance), or if the speakers are shorted.
Hope this helps.
May 04, 2009 | US Acoustics USX-2100 Car Audio Amplifier
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
if you change amps and it goes on protection the speakers are blown causing the amp to protect try changing speakers
Mar 24, 2008 | Car Audio & Video
My amp is on but no sound
Did you disconnect the battery? You may have bowwn a fuse, but that prolly wouldnt give you a protect light. Protect light usually means a short circuit, probably on the speaker end, sure there couldnt be maybe a single strand of wire crossing over the positive and negative speaker or amp terminals.
Feb 29, 2008 | Crunch P125.4 Car Audio Amplifier
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
Flashing Protect light
what are u using to play music??
Feb 12, 2008 | Infinity Reference 5350a Car Audio...
Lightning audio B300.4 amp protect light
The most likely reason for it to go into protect is shorted output transistors.
Jan 16, 2008 | Car Audio & Video
Lanzar Vibe 218 Car Audio Amplifier Logo
140 people viewed this question
Top Lanzar Car Audio & Video Experts
Mike Duncan
Mike Duncan
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
