Question about Whirlpool GGW9250PL Gas Dryer
I can't find the gas line hookup.
Looking for the initial gas line hookup behind the back plate, it's been stored for two years and the line was disconnected.
  • Whirlpool Master
  • 17,173 Answers
I would like to know how to maintain a gas dryer that has been sitting unused for over 3 years, I want to make sure it will be safe to use. Anything I should do before I connect it and start it up?
Providing that the machine was not stored in a wet location or out in the elements you should have no problem. If it were me I would first thoroughly clean the machine, then plug the machine in without the gas line hooked up,start the machine. Let the machine run for a few minutes and listen for the igniter to cycle and for any unusual noises. If everything sounds ok proceed with gas hookup.
Aug 01, 2013 | Kenmore 62602 Electric Dryer
What are the lines. That are just behind the license plate in front of a 1999 Chrysler 300
I take it you are looking at the front of the car through the radiator area? Those could be the Transmission cooling lines if they are bout 3/8" thick-they go to the trans cooler- a small radiator-like piece, or perhaps brake lines if they are smaller going to the passenger side - buit I think you're looking at the trans lines... WHY?
Aug 04, 2011 | 1999 Chrysler 300M
Radio was replaced now heating does not work where do the control hookup to
back behind the radio is were all the vacum lines hook up the cables to change everything are behind the heater controls
Jan 04, 2011 | Mazda Protege Cars & Trucks
Gas but have only electric hookup
Sorry, but there is no conversion from gas to electric. (only natural gas to LP gas or back again) You will have to get an electric dryer or have a gas line run to the dryer.
May 25, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Looking for Nitro binding plates and back strap
Visit the Nitro Snowboard web site and use their store locator to find a store near you. Give them a call and they will be able to help you to order the parts you require.
May 02, 2010 | Nitro Raiden Bolt Snowboard Bindings
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
Where is defrost timer located on frigidaire refrigerator, model no ss180w-1.....17 years old
I couldn't pull up a line drawing for this model, but I recall that on these, (and other fridges of this age and era) had the defrost timer mounted under the front edge of the fridge, just behing the toe kick panel.
Some manufacturers mounted them at the rear behind the thin paperboard "cover", but I'd look for it at the front first.
In either location, it should be mounted behind a metal plate with a small hole in it that has a plastic or metal adjustment shaft that a flat bladed screwdriver slips into to manually advance the cycles.
Just remember to unplug the fridge before you disconnect the timer or attempt to replace it. Once you're done, you can advance the timer to initiate the defrost or cooling cycle, to gets things going.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Frigidaire Refrigerators
I am looking for the location of the plugs on a 2000 mitsubhi mirage with a 1.8 litre engine
Are you referring to the SPARK plugs? The Mirage's 1.8 engine does not use standard spark plugs, because it is fuel injected. It uses 4 fuel injectors that has gas hookups & electrical hookups. They are located on the head in the back.
Jul 28, 2009 | 2000 Mitsubishi Mirage
Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
