Question about Lexmark T650n Laser Printer
935.24 SERVICE PRINTHEAD ERROR. HOW DO FIX THIS ERROR?
2 Suggested Answers
  • 6 Answers
SOURCE: 934 service Printhead error
head may be damaged, try reinstalling software first before you try to send the head repaired locally. may have to buy a new head if its dot matrix.
Posted on Aug 05, 2009
Service printhead error 114.02
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to "RIP Board" on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
"RIP Board" on page 4-11 If this does not fix the problem replace:
Yellow Printhead Assembly - Go to "Printheads" on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the "Printhead Adjustments" on page 4-1.
Feb 15, 2014 | Office Equipment & Supplies
Error code 07,010.43
This is a Process Drive, or a printhead error.
The printhead is probably stuck, or not tilting properly over the drum.
You will need a service technician to fix this.
Apr 19, 2011 | Xerox Phaser 8500/DN Printer
935 service printer head error. how do I fix it?
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Mar 08, 2011 | Lexmark Optra M412 Laser Printer
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
It will not print and is reading 935.15 Service Printhead Error what do i need to do to fix this?
Here's an article in the Lexmark website on A Printhead Error Is Appearing on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/9GQzbO. If all else fails, it may require service. I would also suggest you replace the power supply.
Jun 20, 2010 | Lexmark E450dn Laser Printer
Printhead Error is displayed and therefore rendering the machine unuasable. Do you have any suggestions for a fix?
Replace with new printhead if the print head is past it's service life. If not past it's service life when you get that error message press the online button and it should print fine.
Apr 12, 2010 | Canon imagePROGRAF W8400 InkJet Printer
System error code 07,010.43
Dec 09, 2009 | Xerox Phaser 8560MFP Laser Printer
My Dell W5300 has a message that says "934 Service Printhead Error". How do I fix this?
Hello, Rachel.
That message indicates that you have a bad printhead unit. Your printer would need servicing.
Hope this helps.
Nov 24, 2009 | Dell W5300N Laser Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
Infronprint 1352 93x Printhead error
Basically this is a Lexmark printer.
Try these if no result replace printhead ( can be expensive will try to find the comparable to the lexmark.
93x Printhead Error
Each printhead error has its own error code number. The error codes and their respective meanings are listed below, together with some actions you can take to resolve the problem.
ALL printhead errors:
  1. If this is the first time the error has occurred, try turning the printer off and on.
  2. Let it sit turned off for at least 20 seconds before powering it back on.
  3. If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
  4. If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
    • If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
      • If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
      • If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
    • If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
    • If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
    • If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
    • If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
    • If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
  5. If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
Jul 02, 2008 | IBM Infoprint 1352 Laser Printer
Lexmark T650n Laser Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
