Oil burner runs for an hour then red light comes on
    New Friend:
  • 138 Answers
Are you talking about a Oil Furnace or what exactly?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Posted on Nov 18, 2013
Oil dripping from bottom of burner
Remove the electrodes & nozzle assy
Clean nozzle & check that it is tight
Sand electrodes clean,file ends flat
& set gap
Check the pump for leaks
Mar 02, 2013 | Cars & Trucks
I have an oil fired aga the oil will not come throw to the burner
see the following steps:
f the burner doesn't run, set the thermostat a few degrees higher than normal to see if it comes on. If it still doesn't come on, check switches, and breakers and fuses (see the Electrical Service Panel Fix-It Guide). If the unit has a reset button, press it. Also oil the motor at any oil ports (see below). If the unit doesn't want to start and run, first check the c to make sure that the ignition is getting power. If there is power, check the built-in safety controls (see below) that may turn the system off if they perceive problems.
If the burner cycles too often, replace the filter (see below). Also, oil and adjust the blower (see the Forced-Air Distribution Fix-It Guide).
If the burner runs but won't fire, make sure the oil valves are open and that there's oil in the tank. Check the tank level with a clean stick.
If the burner smokes or squeals, shut off the unit, let it cool, and fill the oil cups. Recheck them after the motor has run for an hour.
If the chimney smokes even after the flue has warmed up, the unit is wasting fuel; call for professional repair.
Safety Controls
Oil furnaces and other heat systems include safety devices that monitor operation and turn off the unit if something goes wrong. In some cases, the safety device can be the problem.
If you encounter an operating problem with an oil furnace, first reset the safety and try again.
If the burner kicks off again, shut off all power at the electrical service panel ; the burner motor and ignition may be protected by separate fuses or breakers.
If the sensor has a photocell, wipe it with a clean rag or tissue and see if the furnace starts.
If the safety is a stack switch mounted on the flue, remove the screw holding the unit to the stack, slide it out, and wipe off the sensor.
If the furnace won't start after three tries, seek professional assistance. Unburned oil can accumulate in the combustion chamber and "flash back."
Jul 31, 2012 | Heating & Cooling
My oil burner trips the m.c.b, what is the cause?
Commonly Reported HVAC Problems: [Copyright © 1996-2011. Hannabery HVAC. All rights reserved.]That would be the little red button on the box at the oil burner itself. If your oil burner stops running the first thing you should check is the reset button. If you press it and the burner fires up then that was the problem. If the button should trip again then there is a definite problem and you should schedule a service call immediately. Do not keep resetting the button and ignoring the problem. afg-redbut.jpg Now, what is this button and why does it trip? It is a safety device. It shuts the burner down when it thinks there is a problem. It is on the primary control and is hooked-up to a cad cell. A light sensor. (The same thing that turns outside lights on at dusk.)
On a call for heat, with the burner running, the cad cell senses the light of the flame. If it stops sensing the light of the flame, it causes the red button to trip, shutting down the burner before any significant damage is done. Next question. Why would the sensor stop sensing light while the burner is running? Many reasons. Almost all of which require a service call. Below is a list of possible causes and things to check. Items in blue usually require a service call. Items in red however can be addressed, even fixed by the homeowner.
  • Faulty or dirty cad cell
  • Faulty primary control
  • Bad or weak ignition transformer
  • Bad burner motor
  • Bad fuel pump
  • Blocked oil filter, strainer or nozzle
  • Delayed oil valve not opening (some units)
  • Cracked electrodes
  • Improperly set electrodes
  • Air in fuel line
  • Burner running with a very high smoke
  • Burner sooted-up
  • Loose electrical connections
  • Damaged flexible coupling
  • Water in oil tank
  • Out of oil - Have your tank filled
  • Chimney blocked - Have it cleaned
  • Closed oil valve - Open valve
  • Air, Pump not primed - Prime pump - may need to call for service
Smart Filters
The bottom causes in red are common problems and can be addressed by the homeowner. Try to check for these conditions first before calling for service. Hope this helps, remember - these are just rough guidelines and not all possible situations are covered.
I found this article on the Web So I can't take credit for it..... But it is a very good place to start for your problem It is what I would start checking if you called me for service .......Good Luck
May 02, 2011 | Heating & Cooling
We ran out of oil yesterday and have now filled tank this morning. Left hand red light is on bottom plinth but when pressed goes off for a few seconds and you can here system start up but then goes out. ...
An oil burner has a high pressure pump on the burner-- can you locate the pump?
(There will be a copper oil line coming into one part of the pump...)
Do you see a little 'Bleeder valve'-- usually right on top-- It takes about a 1/4" (or 5/16" open-end wrench to access it. Air has to be bled from this fitting, until oil comes out.
In order for air to bleed OUT-- the pump has to be running
You can reduce the mess, by slipping a small hose on the bleeder valve, and letting the air, then foam, and then all oil, run into a little can. (Much like bleeding the brakes on your car..)
You may have to cycle the burner a few times, as it times out, from running, but not having JUST OIL, to pump. (These pumps do very poorly, pumping air and oil mixture!-- It must be ALL OIL!)
When you have all oil, tighten the bleeder valve-- Now you will get oil pressure, and you should get ignition. Doyou hear the spark of the ignition?
Tell us more-- and we'll go to the next step
Mack B
Jan 18, 2011 | Heating & Cooling
Our oil tank ran out of oil. We just had it
On the burner unit near where the inlet line enters the unit you will find a little bleeder screw It should require a small 1/4 or 5/16" wrench to open it DO NOT remove it just open it a full turn or 2
Fuel and air will come out of the top of this fitting Once no more air comes out close the bleeder, clean up any spilled fuel and restart the furnace
You may have to do this a couple of times to get all the air out of your lines
Mar 08, 2010 | Heating & Cooling
Yamaha 50 hp motor oil red and green oil sensor lights are on
The engine will self destruct if you continue to run it without the proper oil mixture. Some oil systems have to purged of air if ran dry. Seek professional assisstance.
Aug 21, 2009 | Bass Pro Boating
Firebird 90-120 not starting after it ran out of fuel
on the lh side of the burner, there is the pump if you could look at it straight on there is 4mm allen screw at about the 2 o'clocl on the face of it, usinging a allen key loosen this then with the heating switched on, press the red reset button on the burner (round with red light) and the burner should run, where the screw is loosened you should see the oil bubble out, the run freely, the burner will fire, quickly tighten the screw back in. you may need to repeat to get it to work
a container under where your doing this will help
Feb 13, 2009 | Ruud Handler Air Conditioner
Burner will run for a couple of hours and then turn off.
They could have disturbed the sludge in the tank when refilling. If you do not have a filter in place it may have clogged the pump or jet and making it hard to start. These need yearly maintenance anyway. The pumps usually have a screen inside and the jet has a screen inside. First,open the bleed on the pump and purge some oil from the line and see if it is flowing freely. If so, the take the drawer assembly out and clean it. Make sure the jet is clear, by blowing through the attached oil line. You should see/feel a fine mist of oil come out. Electrodes should be about 5/32" apart for an F5.
Jan 14, 2009 | SySTOR Systems (400S52) Burner
Riello oil burner
i have a reillo oil burner that fires up from cold no problem reaches the set temp and cuts out, when it tries to kick back in it keeps clicking the lockout light is not coming on and the fan is still running any ideas?
Oct 08, 2008 | SySTOR Systems (400S52) Burner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
