Question about International KDV-8000 Pal to NTSC Video Converter HDMI 1080p HD
Can you hook up a blu-ray player to a Samsung TX-R2765 TV? I don't see an HDMI plug.
HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video AV CVBS Adapter HDMI 2 AV Converter Supports PAL/NTSC for HDTV DVD Amazon com HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video...
Nov 19, 2017 | Televison & Video
Tip
Convert TM900 1080/60p and 1080/50p AVCHD MTS footage to ProRes 422 for Editing...
Edit TM900 1080p 28Mbps AVCHD MTS to ProRes 422 in FCP
The HDC-TM900 High Definition Camcorder is a HD offering from Panasonic.While you record 2D videos in 1080/60p (1080/50p for PAL model) at 28Mbps with Panasonic HDC-TM900 .If you would like to put the AVCHD videos from TM900 to Final Cut Studio for editing, a third party software shall be needed to handle the 1080/60p and 1080/50p footage to ProRes 422 for FCP 6/7. Aunsoft Video Converter for Mac is the recommended Panasonic TM900 AVCHD to ProRes converter for high quality video editing on Mac with less compressed Apple ProRes format.
Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Here is the step-by-step guide for you to Convert,import and edit Panasonic HDC-TM900 MTS to Apple PreRes 422 MOV to Final Cut Pro/FCP7 without rendering on iMac/MacBook Pro with Mac OS X like Snow Leopard.
Step 1. Load Panasonic HDC-TM900 videos to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best MTS video to ProRes converter on Mac, click the "Add" button and you can browse the TM900 28Mbps videos for conversion.
Step 2. Choose Apple ProRes for Final Cut Pro.
Click the "Format" option, and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The video to ProRes 422 converter will transcode Panasonic HDC-TM900 1080p AVCHD to Final Cut Pro native format.
Step 3. Choose 1080p size with 60 or 50fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution. Click the drop-down box for frame rate, and choose 60fps or 50fps as output video frame rate. The frame rate option depends on your source videos in NTSC or PAL model. Click the OK button to save the changes and the Mac AVCHD video converter will convert 1080p AVCHD videos to 1080p ProRes 422 Mac FCP compatible native format.
Step 4. Convert 28Mbps MTS to Apple ProRes for FCP.
Click the convert button under the preview window, the conversion from Panasonic TM900 AVCHD to ProRes 422 MOV Final Cut Pro Native Format will start immediately.
After converting and merging the Panasonic HDC-TM900 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920×1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro.
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Light blinking
that internal your converter was damage just return it
Nov 27, 2013 | Orei XD-901 Multi-System PAL/NTSC Signal...
How to unblock region code block of sony bdv-e770w?
It's already Region Free when purchased.
  • A+B+C Multi Zone Region Code Free Blu Ray Player DVD Region 123456 PAL/NTSC
  • PAL or MULTI-SYSTEM TV is required to watch PAL DVDs. If your TV was purchased in North America (NTSC) you will also need a Video Scaler Full HD 1080p.
    May 07, 2011 | Sony BDV-E770W 3D Blu-ray Theater System...
    How do I get my 52inch rca scenium to show 1080 using my ps3
    Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
    1.
    Check the resolution supported by your TV.
    Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
    2.
    Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
    3.
    Select [Video Output Settings].
    4.
    Select the connector type on your TV.
    Resolution (video mode) varies depending on the type of connector used.
    videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
    *2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
    D5: 1080p / 720p / 1080i / 480p / 480i
    D4: 1080i / 720p / 480p / 480i
    D3: 1080i / 480p / 480i
    D2: 480p / 480i
    D1: 480i
    *3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
    *4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
    5.
    Change video output settings.
    Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
    videooutput003.jpg 6.
    Set the resolution.
    Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
    * The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
    If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
    If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
    videooutput004.jpg 7.
    Set the TV type.
    Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
    videooutput005.jpg 8.
    Check your settings.
    Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
    videooutput002.jpg 9.
    Save your settings.
    The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
    Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
    Feb 28, 2011 | RCA Televison & Video
    How can I convert the Nuvico NVJV 8000 from NTSC toPAL?
    I have the DV3-8000; the service menu can be accessed by holding down keys 1 and 3 simultaneously; there is an option to select either NTSC or PAL; my GUESS is select PAL; don't know if there is more to it than that, but this is a start . . .
    Jul 28, 2010 | Nuvico NVJV-4000N Video Recorder
    PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
    I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
    Jan 06, 2010 | Sony Playstation 3 (PS3) Console
    I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
    1. Check the resolution supported by your TV.
    2. Select (Display Settings) under (Settings) in the home menu.
    3. Select [Video Output Settings].
    4. Select the connector type on your TV.
    D2: 480p / 480i
    D1: 480i
    5. Change video output settings.
    6. Set the resolution.
    7. Set the TV type.
    8. Check your settings.
    Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
    9. Save your settings.
    The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
    Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
    NTSC -> PAL converter: would it help my prob with my PS3?
    You'll need to buy the converter. Ebay usually has them for the best price around. If you wanna keep the hdmi they're usually around $200 for the converter. You could save yourself a bit of trouble depending on your situation by just selling your pal ps3 and getting an ntsc version instead.
    Let me know if you have more questions.
    Best of Luck!
    Feb 25, 2009 | Sony PlayStation® 3 (60 GB) Console
    International KDV-8000 Pal to NTSC Video Converter HDMI 1080p HD Logo
    93 people viewed this question
    Top International Televison & Video Experts
    Are you an International Televison and Video Expert? Answer questions, earn points and help others
