Question about Bose QuietComfort 2 Consumer Headphones
Battery corroded Battery is corroded and Ican;t get it out. What can i use?
REAR RIGHT SIDE DOOR WILL NOT AUTO LOCK NOR DO THE WINDOW GO DOWN
sounds like a loose plug in the door. also open the door and visually check the boot and wires coming out of the door. some times these wires corrode/white ask effect. clean with battery turminal cleaner spray from auto store.
Feb 10, 2014 | 2000 Buick LeSabre
Corroded battery in high beam 1watt
battery sat inside to long or was overcharged... not worth saving
Dec 29, 2013 | Rayovac Highbeam Flashlight 1 Watt Luxeon...
FurReal Lulu kitty batteries corroded and rusted battery compartment. Can compartment be repaired/replaced?
You have to clean the contacts that touch the battery with a metal screwdriver, rub them until the metal shines.
Dec 21, 2013 | Tiger Electronics Toys
Bios password ican not to remove it and if i remove the battay of bios ican,t remove it either
1) Open up case of desktop
2) Locate BIOS Battery
3) Locate Jumper Switch near BIOS Battery
4) Reposition Switch setting from 011 to 110
5)Reset Computer
6)Reposition Switch from 110 to 011
This procedure resets the Basic Input Output System without having to remove the BIOS Battery. It should solve your problem.
Dec 02, 2013 | Dell VOSTRO 1015 T6570 21G 2GB 160GB DVDRW...
Corroded battery cable?
To do a good job if you havent already done it is to tip hot water over the battery term and it will dry clean ,,if corroded term then replace it but you dont have to buy with a new lead ,,only a positive term only and then hot water over the battery lug when new term on then spray with Hair spray .
If battery cable dident corrod with other battery then your battery is either charging more than 13.5 volts and or battery post to battery is cracked
Wash and spray then check first
Sep 27, 2009 | 2002 Toyota Camry
Internal battery terminal corroded and fell off
Old batteries leak and the battery terminals corrode. Replace the terminals and clean the area thoroughly.
Jul 27, 2017 | Canon Optics
Bose QuietComfort 2 Consumer Headphones Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
