Question about Mattel Hot Wheels 16 Speed Demon Bike
Chain guard - Mattel Hot Wheels 16 Speed Demon Bike
Two banging sounds with each rotation
Most beach cruisers have a chain guard. There is always a slight "wobble" of the front chain ring, check to make sure the chain isn't slapping the chain guard. The chain guard can be adjusted. The chain also might have loose tension causing it to bounce around just enough to hit the chain guard. The opposite may be true, if the chain is too tight, you could be getting a popping sound at certain points on the chain as it messes with the gear teeth, in this case loosen the chain slightly to put a little slack in it.
Jan 14, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
Chain came off
Take off your chain guard, should be 2 bolts holding the chain bar in place. Then make sure there isnt another bolt or screw you missed, pop off cover put chain on, replace chain guard and tighten chain. It should be that simple
Jul 22, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chain dowsn't stay tight
Between the chain bar and the body there is an adjusting screw, if the adjusting screw is stripped it will not pull on the chain bar to tighten the chain.
procedure for tightening chain. loosen the chain guard nuts, tighten the bar adjusting screw by turning to the right or clockwise, the chain has to roll freely around the bar but not bind. check with gloves or rag, don't use bare hands to avoid accidents. once chain is adjusted, tighten the chain guard nuts. good luck!
Oct 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I can not get the cover to fit back over the chain and blade. The interior flat wire does not fit back over the round chain drive. It is like the brake is still on.
The chain brake is activated, if the hand guard is connected to the brake cover, carefully clamp the brake in a vice ( be careful not to damage the cover ) now pull the hand guard fully back until the brake clicks off, if the hand guard is on the saw itself, remove the two screws and remove the hand guard, use this as a tool to fit into the brake and load it.
Jun 28, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw blade will not turn?
If the saw is running and the chain doesn't turn, chances are you tripped the kick safety (the guard in front of the top handle) Push that guard back towards the handle firmly until it clicks. It should work now. The other possibility is if you just changed the chain that the safety isn't correctly engaged with the guard.
Mar 06, 2010 | Standard Oregon Chainsaw Chain For Stihl...
I just bought a La Jolla 26' men's bike and the pedal stem is scraping on the chain guard. How and where do I make adjustments?
Examine the top of the chain guard where it mounts to the bicycle. Loosen the fasteners enough to slide the chain guard in and out. Adjust it so it doesn't hit the crank or rub on the chain and tighten the fasteners back down.
Jan 19, 2010 | Cycling
I am trying to replace the chain on a swinn pixie bike--but thereis a chain guard that is giving me troubles--I need to know how to assemble the chain with the guard
see if theres a master link on the chain and take off from that way you dont have to take off the guard. the master link will look diffrent from all the other links and can normally be removed with a screwdriver
Jul 02, 2009 | Cycling
Mattel Hot Wheels 16 Speed Demon Bike Logo
Top Mattel Toys Experts
thegtw
Tracy E
Level 1 Expert
Tom Chichester
Are you a Mattel Toy Expert? Answer questions, earn points and help others
