Intermittent vertical black lines samsung hlp5067w
Hello, I have a Samsung HL-P5067W (model code: HLP5067WX/XAA) rear-projection TV. I got it for free from a family member, being told that it needs a lamp. I purchased a new lamp and installed it. I reset the lamp hours meter and did the factory reset for the settings. Since installing the lamp, the TV powers up and functions properly, with the exception of several vertical black lines fading in and out across the screen. Other than the lines, the picture has fantastic colors and is very clear and bright. The lines sometimes completely go away for a while. They seem to come and go without reason. Is this the digital board? If so, does anyone know what in particular goes bad on that board? I am an electronic technician and would be able to replace individual components.
    New Friend:
    Problem Solver:
  • 8 Answers
Even technicians who are familiar with those units, before installing new lamps, they use a 'calibration unit' for that or any particular model lamp and calibrate them right after installation. If you don't have the proper calibrator and adjust them right after you installed them, you will get that result. Even experience techs come across that problem if the calibration is not done properly. Also, each lamp for a different color value, has its own calibration/sync values.
Posted on Nov 18, 2013
2 Suggested Answers
asnowman
  • 788 Answers
SOURCE: installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 01, 2009
Intermittent black lines samsung hlp5067w
When the lines are showing, check to see if you can see them with the on screen menu being displayed, if you can then it is the DMD board, if you cannot then it is just the digital board.
Nov 18, 2013 | Televison & Video
Samsung HLP5067WX No sound from internal speakers
Check ur tv it is not on mute mode.Try go into tv menu go to Audio Seting reset every back to factory setting.Check ur tv Audio Setting is it not on VARIABLE setting.Must be on FIX setting to able to used tv internal speakers.These steps should help tv get audio back.
Aug 08, 2011 | Samsung HLP5067W Television
Hello...... what is the modle # color wheel the Samsung HRL 5067 WX/XAA? I have not pull the old one out. I look everywhere and I found everything except the one that matches that TV. Could anybody help? I...
Model number should be HLR 5067 Color Wheel PN# BP96-00674A
Encompass Parts has them for $147.11 1-800-638-3328
Samsung Parts.com 1-800--627-4368
You can also look on Ebay under Electronics/ TV Parts
Jul 26, 2011 | Samsung HLP5067W Television
I have a black line on the tv samsung
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help......
Jun 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My samsung hl-p5067w does not work
I would see if it's the lamp ballast only about $100.00 and easy to replace, it's the part underneath the lamp that fires up the bulb. The light engine itself is over $900 to buy and not worth it! I have same T.V.
Jan 31, 2009 | Samsung HLP5067W Television
Samsung dlp model hlp5067wx
the color wheel has to be replaced. (Technican Job) this device is inside the light engine,
Jan 06, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Nov 05, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
