Intermittent black lines samsung hlp5067w
Hello, I have a Samsung HL-P5067W (model code: HLP5067WX/XAA) rear-projection TV. I got it for free from a family member, being told that it needs a lamp. I purchased a new lamp and installed it. I reset the lamp hours meter and did the factory reset for the settings. Since installing the lamp, the TV powers up and functions properly, with the exception of several vertical black lines fading in and out across the screen. Other than the lines, the picture has fantastic colors and is very clear and bright. The lines sometimes completely go away for a while. They seem to come and go without reason. Is this the digital board? If so, does anyone know what in particular goes bad on that board? I am an electronic technician and would be able to replace individual components.
  • Televison & ... Master
  • 16,243 Answers
When the lines are showing, check to see if you can see them with the on screen menu being displayed, if you can then it is the DMD board, if you cannot then it is just the digital board.
Posted on Nov 18, 2013
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Feb 18, 2014 | Samsung HLP5067W Television
Intermittent vertical black lines samsung hlp5067w
even technicians who are familiar with those units, before installing new lamps, they use a 'calibration unit' for that or any particular model lamp and calibrate them right after installation. If you don't have the proper calibrator and adjust them right after you installed them, you will get that result. Even experience techs come across that problem if the calibration is not done properly. Also, each lamp for a different color value, has its own calibration/sync values.
Nov 18, 2013 | Televison & Video
Samsung HLP5067WX No sound from internal speakers
Check ur tv it is not on mute mode.Try go into tv menu go to Audio Seting reset every back to factory setting.Check ur tv Audio Setting is it not on VARIABLE setting.Must be on FIX setting to able to used tv internal speakers.These steps should help tv get audio back.
Aug 08, 2011 | Samsung HLP5067W Television
Hello...... what is the modle # color wheel the Samsung HRL 5067 WX/XAA? I have not pull the old one out. I look everywhere and I found everything except the one that matches that TV. Could anybody help? I...
Model number should be HLR 5067 Color Wheel PN# BP96-00674A
Encompass Parts has them for $147.11 1-800-638-3328
Samsung Parts.com 1-800--627-4368
You can also look on Ebay under Electronics/ TV Parts
Jul 26, 2011 | Samsung HLP5067W Television
I have a black line on the tv samsung
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help......
Jun 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My samsung hl-p5067w does not work
I would see if it's the lamp ballast only about $100.00 and easy to replace, it's the part underneath the lamp that fires up the bulb. The light engine itself is over $900 to buy and not worth it! I have same T.V.
Jan 31, 2009 | Samsung HLP5067W Television
Samsung dlp model hlp5067wx
the color wheel has to be replaced. (Technican Job) this device is inside the light engine,
Jan 06, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
