Question about InStyler Hair Iron Pink/Black
I have a Instyler Rotating Iron and I heard a popping sound and it is not working
How to fix it?i put it on 220 and its 110
sorry but there is not fix for that .
Oct 23, 2015 | InStyler Rotating Iron
Noise every few minutes
there may be clicking sounds heard form you device when it is regulating tempature, if the sound is sizeling than this might indicate a problem with the device that regulates the temprature and might eventualy need to be repalcaced
Oct 20, 2013 | Applica BD Continuous Steam Pro Iron -...
Was using iron with no problems when heard a pop and now wont work. Not the outlet. Is there a fuse that could blow, and is this something that is easily fixed? or is it better just to purchase a new...
Most likely it was the thermal overload, its a type of fuse, but could be a capacitor on the circuit board. The history of this iron's failures would lead me to tell you to get another on and not a Black and Decker. repair costs would be $25.00 and up just to get someone to look at it and parts for these are not widely available so any parts you get would cost extra for shipping. Wouldn't hurt to open it up and see if it is something simple but I would not pay to have it repaired!
You can only tell for sure by taking the unit apart and testing the circuit for continuity.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
A bad reading is almost assured with what your telling me .
Aug 23, 2011 | Black & Decker D6000 Iron
I was ironing using the Rowenta, there was a loud pop, the iron shut off and has not worked since.
It sounds like you have had an electrical short-circuit. Depending on where the short occurred, it may or may not be fixable. If it was just in the plug, or where the wires connect into the iron, then no problem to repair, but if it was in the element itself then not much can be done.
Dec 08, 2010 | Rowenta Irons
I get lots of brown stained clothes when i use my tefal steam generator iron have tried to de-scale it using the hose and then using 1 part vinegar to 3 parts water and it still keeps happening anyone...
Ok. sounds like you have lots of iron( Fe) in your water. You must always use only distilled water in the unit or you will get stains and eventual failure of the unit. The other possibility is contamination of the ironing surface or ironing spray product. 250 Pounds is the most expensive iron I have ever heard of outside of a commercial model,so it would certainly be worth taking to a shop for checking if nothing else works. I wish you good fortune, farmerbear at FixYa.com
Sep 29, 2010 | Tefal Irons
Boiler on the iron was empty,used by someone that didn't know this type iron.Turned iron on and later heard this awful noise and husband tried to release pressure and cap blew off but no water was in...
I do not use this model, but it would appear the iron is not affected, just the boiler - like setting an empty tea pot on a hot burner.
Is there any warning that the tank is empty before turning the iron on?
I would refer to the manual for cleaning before using the iron and would not loan anything more valuable than a cup of sugar to anyone.
Mar 19, 2010 | Rowenta DG5030 Iron
Shark Euro Pro Iron turns of while ironing
what makes the water spit out of the iron and make my clothes wet
May 05, 2008 | Euro-Pro Shark GI490 Iron
InStyler Hair Iron Pink/Black Logo
35 people viewed this question
Top InStyler Irons Experts
Are you an InStyler Iron Expert? Answer questions, earn points and help others
