Question about Ricoh Aficio 2022 All-In-One Laser Printer
SC542 A functional problem has occurred with the printer. Turn the power switch off and then on. If the problem continues please call service.
5 Suggested Answers
  • 114 Answers
SOURCE: I have a Functional Problem. The little wrench
SC542: Fusing temperature warming-up error The fusing temperature does not reach the fusing standby temperature within 135 sec (35CPM machines) or 145 seconds (45CPM machines) after the main power switch is turned on. - Possible causes - • Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermofuse open • BICU defective • Power supply board defective • Poor fusing unit connection
Sometimes by going into service mode and then turn off copier and back on will clear this message or while in service mode do an error clear. But most of the time it is the thermistors in the fixing unit needs to be cleaned or replaced. I would probably call in the techs.
Posted on Mar 22, 2010
  • 26 Answers
SORRY JEFF.THE PROBLEM IS AFUSER TEMPERATURE ERROR.
POSSIBLY JUST DIRTY THERMISTORS IF FUSER REBUILD IS
NEEDED THINK 600.00
Posted on May 17, 2010
  • 525 Answers
SOURCE: Error occured SC:302 Functional Problem Turn
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
Posted on May 27, 2011
tinualbinale
  • 436 Answers
SOURCE: Hi, I have a Printer
This error code means temperature fusing problem. Check all of the connectors on the fuser connector and receptacle, just to make sure that full contact is being made.According to Ricoh direct techs after 100K to 200K copies on a new machine the Hot Roller would start to warp (ever so slightly) because of its thin wall construction (fast warmup time).Replacing the Hot Roller will solve the problem.Please don't forget to rate me if satisfied.
Posted on Jun 07, 2011
Error sc540
Error code is related to the Heater section. You have to contact a technician
Apr 24, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
Error sc540
fuser assy replace and reset code or have tech come out
Sc542
Press Clear(yellow)key then press 107 press and hold Stop/Clear(red) key more than 3 second select SP modes,open a front door,turn off the power switch,wait 2 minutes,close the front door and turn ON the copier.
SC 541-542 fuser unit thermistors or thermofuses malfunctions.
Jan 22, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
I have a Functional Problem. The little wrench shows on the User Tools / Counter button location and on the screen. The Functional Problem code looks like SC542-00. It tells me to shut off copier and turn...
Mar 21, 2010 | Ricoh Aficio 450 Copier
Functional error SC542
This is a fuser temperature heating error.
the fuser has not heated up within 5 minutes after switching the copier on.
Most likely cause:
Heater lamp blown
Thermal fuse blown
Faulty power supply
Bad connection to fuser unit
You will need a service technician to fix this.
Dec 07, 2009 | Savin Office Equipment & Supplies
My copier keeps indicating the spanner function.it is saying problem sc5042
my think its not sc 5042 it will be SC542: Fusing temperature warm-up error -Definition- [A] The fusing temperature does not reach the fusing standby temperature within 50 seconds after the main switch is turned on. - Possible causes - · Fusing thermistor defective or out of position · Fusing lamp open · Fusing thermofuse open · Power supply board defective · Poor connection of the fusing unit
5-810 SC Code Reset Resets any service call condition. After performing this SP mode, turn the machine main switch off and on. See "Troubleshooting - Service Call Conditions" for how to use this mode. 0: No 1: Yes
Sep 21, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh 2090 SC542 error
model 2090 richo sc 542 thermistar and hetar mail cancektar parobelam
Aug 22, 2009 | Office Equipment & Supplies
Ricoh Aficio 2022 All-In-One Laser Printer Logo
503 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
