Question about Advent Computers & Internet
I turned on my laptop and the keyboard is none responsive, the cursor pad however still works, i tried turning it on and off again and rebooting still no use, i tried the num lock still no use is there a solution
    Sergeant:
  • 486 Answers
Try cleaning your keyboard with isopropyl alcohol for dirt clogs and run an air blower over your keyboard.Start you computer and see if it works if not then take it to a local repair shop for repair.
Good Luck.
Posted on Nov 18, 2013
vincent721
  • 240 Answers
SOURCE: How to turn off number lock
Press Hold Fn key + F4
or change the setting to bios Set up to Disable Num Lock
Posted on Mar 13, 2009
moz205
  • 80 Answers
SOURCE: Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Posted on Dec 22, 2007
PABLOCSA
  • 1124 Answers
SOURCE: Toshiba Laptop Satellite A15-S157 Mouse Cursor stuck in one place(Locked)
To get enable or disable the Touch Pad you have to pulse the Fn + F9
You can also set this function as follow:
Start >> Control Panel >> Printers and other hardware
Click Mouse >> Touchpad (enable or disable)
Posted on Oct 27, 2008
SOURCE: frozen mouse and keyboard on acer 3100 notebook
acer notebook- froozen keyboard and touch pad.......any help
Posted on Feb 21, 2009
  • 44 Answers
SOURCE: num lock activated and can't turn it off
One of your Function keys (F11, F12, etc., usually F11) will also have the NumLock function on them. So when you hold Fn and press F11, it will toggle the Number Lock. Try holding Fn and press F11, this should turn it off (and back on should you ever want to use it again). Your keyboard should be labeled with the various functions keys have when Fn is pressed, you may have to look for the one that reads NumLk.
Posted on Sep 09, 2009
Why has my mouse stopped working, also the touch pad on computer has stopped?????
Janice, This is info from Tomsguide.com
1- Turn off computer, disconnect the power cord, remove the battery.
2- Press the Power On button for 10 seconds
3- Replace battery and/or connect power cord.
4- Turn On computer + immediately press F2 key repeatedly
5- Press F9 then press Enter
6- Press F10 then press Enter
May have virus or corrupt driver, run your anti virus and try reloading divers for mouse and touch pad, you may have to use system restore to an earlier date when thins were working OK.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ccm.net/forum/affich-689275-toshiba-satellite-mouse-pad-stopped-working
Toshiba Satellite keyboard and touchpad don work
Toshiba Satellite Cursor is not responding
Jul 31, 2016 | Toshiba Computers & Internet
Can't unlock keyboard
hello,
try the following:
press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it
Oct 12, 2012 | Toshiba Computers & Internet
Frozen keyboard - compaq cq 61
When I like to make a Xp Insaillation in my Computer Amilo li 3710, After booting CD Coming some blue screen error massage in my computer.
May 27, 2010 | Computers & Internet
Cursor tend to go spastic when I touch the keyboard on my Dell
hi,
I had this problem and it was solved by turning off the touchpad in the bios,
Pressing the f10 ? or f2 ? during startup will get you into the bios
are you sure the mouse is ok ?
Regards
GeWiz.
Dec 10, 2009 | Dell Latitude D800 Notebook
Laptop cursor jumps around, turns crosshair, screeturns black
windows vista is probably the problem...have you tried running a virus scan? McCaffe...could actually have one from the factory
Oct 05, 2009 | Acer NSK8458AN Keyboard
We have a Dell D600 Micrsoft XP and the cursor is locked
Does the keyboard work? If so, you'll need to do your best to use the keyboard to download and install these drivers here.
Jun 14, 2009 | Dell Latitude D600 Notebook
Touch pad is none responsive but the laptop will work with mouse.
try uninistalling the touchpad in control panel>device manager. You will find it under pointing devices, reboot the computer and it should be picked up as new hardware and be reinstalled.
I hope this helps
Feb 24, 2009 | ASUS Computers & Internet
Laptop keyboard issues
Is this a laptop? Some laptops will allow you to use these keys as the number pad/arrow pad as well in a certain mode. You will likely be able to turn off with a combination of the FN key plus one of keys F1-F12 (the function key will perform the action shown as a symbol on these keys).
If none of the symbols seems to indicate this mode. Try each combination and test to see which combination sets your keyboard mode back to normal.
Jan 05, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Computers & Internet Logo
Top Advent Computers & Internet Experts
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
