Question about Panasonic VIERA Televison & Video
Replacement parts My HDMI Ports blew during a storm. I am looking to get the part # and instructions on how to change the part.
  • Panasonic Master
  • 16,043 Answers
What is the exact model number of the television?
Posted on Nov 18, 2013
crapiemael
  • 241 Answers
SOURCE: HDMI ports do not work after lightning storm
Probably not, but your insurance should pay if you have a renter or homeowner policy.
Posted on Jul 21, 2009
MaverickIT
  • 53 Answers
SOURCE: lightning storm and all hdmi connections stopped working
It may be a problem with the DVRs. You can rule that out by connecting a different HDMI TV to one of the DVRs.
Posted on Aug 29, 2009
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Posted on Apr 25, 2011
  • 1704 Answers
SOURCE: hdmi ports not working after
Hi, During a lighting storm unplug or get a surge protector. Your too late to do anthing now. Go to a repairman. good luck.
Posted on Jun 29, 2011
  • 35 Answers
SOURCE: hdmi portd not working anymore on lg47lh40
the chip in the tv maybe fried or may need to be reflashed (reprogrammed), contact manufacture, hopefully it is still under warranty or find a tv guy, buy a surge protector so it doesnt happen again
Posted on Jul 09, 2012
Testimonial: "Thank You. I will follow up on your suggestion tomorrow, and will try to find out if it's still under warranty. Just can't understand everything else work except for the HDMI ports."
TV Will not power on
HAVE YOU CHECKED PLUG AND INTERNAL FUSES
May 28, 2015 | Televison & Video
HDMI ports not working on a LG 471V5500 tv after lighting storm
If your other inputs are working, then you will need a Main pcb.
Try the following web site, but you will need the complete mode# for the correct pcb for your unit:
http://www.shopjimmy.com/tvs/tv-main-boards?tv_brands_select=Lg&tv_models=Lg+47LV5500-UA
Feb 14, 2015 | LG Televison & Video
All 4 HDMI ports are not working after a storm blew out cable box. All other inputs work
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 13, 2015 | Panasonic Viera Tc-p65vt30 3d 65 1080p...
How do you repair bad hdmi ports on Denon receiver all 4 not working
Sounds like you fried some circuitry or blew some fuses. I'd take it to a repair shop.
Aug 22, 2014 | Denon Audio Players & Recorders
Visio 420m hdmi ports and remote dont work after storm
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 14, 2014 | Televison & Video
During a storm a bit ago all the HDMI ports stopped working I am looking to fix them finally and wondering if anyone can help w a part # and instructions.
A basic understanding of electronics helps. I would look inside on the board and follow the traces from the hdmi back to the chip that feeds it. It would likely be an ic that has a voltage regulator in it as well as something to convert the serial port data. Write down the numbers on the chip and go to or phone an electronics parts supplier in your area and they will consult a cross reference manual to see if an after market version of the chip exists. If not they will order the original. Once you have the chip, you will need a decent soldering station ($100 or so) and a solder sucker. The solder sucker is used to desolder the chip or component slowly. Don\'t overheat the component but desolder as far as you can. then wiggle each leg one at a time until it breaks the remaining solder. If it does not wiggle off heat it again then wiggle it. Once all unsoldered gently pry out. (any other attempt to desolder without a solder sucker will damage the printed circuit traces) Before removing the ic verify which pin is pin 1. It may be printed on the board or a corner of the chip is marked somehow. Place the new chip in with pin 1 in the proper location. Use hitech solder that is hollow and contains flux on the inside to resolder. If the wrong solder is used the flux may attack the components and it will fail within a year (plus or minus). I would suggest finding someone who already does some electronics to assist you or to do the whole job.
Nov 18, 2013 | Panasonic Televison & Video
Hdmi ports not working after thunder storm
Jun 29, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
Jul 21, 2009 | Panasonic 50 in. Plasma TV
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
