Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
Need red and black tripper switch for Malibu ML300RTW
3 Suggested Answers
SOURCE: trying to see if there
Power packs are one of those expensive items that can't be repaired.
If receptacle has power and bulbs are good, then power pack should turn on lights using manual override switch.
If power pack is not making humming sound, and there is no spark when you scrape a wire across wire terminals, then the power pack is dead.
Power packs don't come apart for repair.
There is no fuse or reset button.
And they don't have repair parts available on Intermatic or malibulights.com or e-bay.
However power packs have 5 year limited warranty.
'Harry' wrote me last month and said he was in contact with Malibulights.com for warranty reimbursement. I hope he writes back and says how that came out.
http://malibulights.com/customer_service/contact_us.aspx
'Harry' also came up with ingenuous solution if power pack still turns lights ON. His timer stopped working. He bought a cheap plug-in timer and then connected power pack to that timer.
You can add a comment and let me know what happens.
Fixya also offers phone support for a fee. The paid specialist can tell you the same information for a fee.
After hours researching power packs at Intermatic, Malubulights.com, ebay etc, the best I found were tips for next power pack that might save money:
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Posted on Dec 18, 2010
SOURCE: i have the ML300RTW transformer. Just need to know
Here's how to check your power pack: Connect everything and set trippers randomly, and then manually rotate dial clockwise and watch when lights turn on-off, this will let you check if you have trippers set correctly.
As time passes, the dial rotates, and trippers push on-off lever that turns low-voltage lamps on-off.
If trippers no longer work, it's because trippers are worn down or the lever is worn out or the electrical contacts have burned. And the clock motors slow down and burn out.
There are no repair parts for low-voltage transformers. No trippers or timers.
"Harry" wrote to fixya with idea when timer no longer works: he bought cheap plug-in timer, set power pack to override, and then plugged power pack into cheap timer.
Since there are no repairs for low voltage transformers, I found tips that might save money:
The reason I add tips now, before power pack needs replacement is some fella wrote fixya.
a) Match wattage of bulbs with wattage of power pack
Lets say you have fifteen 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or it may burn out.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 31, 2011
Timer will not trip. do I have wrong tripper?
Unknown if this is about setting up new timer, or about timer that worked before and trippers need replacement.
Open following link for instructions in troubleshoot format, and links to replacement trippers and tips for having power pack to last longer:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Aug 11, 2011 | Malibu Intermatic Inc. ML300RTW 300-Watt...
HI , I would like to know what the red tripper represent "on" or "of " ?
The red tripper is ON.
Put trippers into dial, and then manually rotate dial to see how the lights turn on-off.
Rotate the round override switch and then rotate the dial again to see what affect the override switch has.
These actions will help you understand how to set power pack.
For replacement trippers and money-saving tips and useful troubleshoot information:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
May 22, 2011 | Intermatic Malibu 300W Power Pack...
Red pin missing from friend's Malibu outdoor timer. Need to replace. Numbers / info on timer: 120V 60hz, 600 W Max, 158ML, 1194B 300 W/Sec 06A
Open following link for power pack resources including link to Intermatic ML series trippers.
Same tripper fits all ML series timers.
For all Intermatic trippers and parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
May 17, 2011 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Where can I purchase the plastic tripper switch
You posted under Intermatic or Malibu power packs:
For full information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips: Including order form and direct link for ML series black and red trippers
Nov 10, 2010 | Malibu ML200RT - Low Voltage Power Pack...
I need instructions for setting the timer
Malibu product manuals
http://www.malibulights.com/customer_service/owners_manuals.aspx
Manual for 300 Watt power pack
http://malibulights.com/docs/pdf/8100-9300-01.pdf
Read cautions
Tips
300 Watt power pack requires sum of bulbs to equal 300 Watts
If you use 10 - 20 watt bulbs that is only 200 Watts so you need 200 Watt power pack
Replace burnt out bulbs immediately or other bulbs will burn out and shorten life of power pack
When working on bulbs, unplug power pack so it does not shorten life of power pack
Set Malibu Timer:
Red trippers are ON
Black trippers are OFF
Place trippers on dial at ON OFF times/ AM and PM
Set current time of day:
Plug in power pack
Trippers are installed
Rotate dial counter-clockwise to current time, say 9 am
Rotate dial 2 more revolutions and then return to current time
That's it
Oct 12, 2010 | Intermatic Malibu 300W Power Pack...
I have lost the little plastic pegs that turn the time on and off can you tell me where I can buy them.. Home Depot and Osh do not have them
According to Intermatic literature, ML series Power Pack uses 107SB189 ON tripper, and 107SB192 OFF tripper. I have not ordered these trippers and no image seems available.
Red On tripper available at IntermaticStore.com
Black Off tripper available at IntermaticStore.com
Tripper order form
For more information on power packs:
http://www.fixya.com/support/r8391011-power_pack_not_working
Jul 08, 2010 | Intermatic Malibu 300W Power Pack...
I have a Malibu 600 watts low voltage transformer that works only for 30 minutes and then, will turn on again for another 1 hr. I only want to turn on one time but for 4hrs. I already removed one red and...
There are no repair parts for intermatic/malibu power packs.
If problem timer malfunction, then set power pack to override, buy cheap plug-in timer, and plug power pack into cheap timer.
If problem is internal wiring, then replacement is option.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Sep 01, 2009 | Intermatic Malibu 300W Power Pack...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
