Question about Huth Manufacturing Tools & Hardware - Others
Huth mitey mate 2 wiring diagram - Huth Manufacturing Tools & Hardware - Others
Need wiring diagram
Mate what make and model car is it, I google "wiring diagram for" and add make and model.... It's easy.... CHEERS...
Mar 12, 2016 | Cars & Trucks
I need a wiring diagram for 1972 dodge truck
Mate this is a link to a wiring diagram for 1972 dodge challenger, They're saying It is wise to first read to understand the wiring schematic before making any wiring changes on your Dodge Challenger to avoid any wrong wiring connections. By-the-way, you can clink on the diagram to enlarge the image and clink on it again to see which wires are the right colours, CHEERS..
http://www.auto-wiring-diagram.com/620-electrical-wiring-diagram-of-1972-dodge-challenger.html
Mar 12, 2016 | Dodge Cars & Trucks
I want rubber washer to attach hose pipe of mitey euroclean ec300
Go to a used vacuum place they will have them there.
Jun 25, 2014 | Vacuums
How to check wether a motor is working
I remove the power wires going to the motor and wire a power cord directly to the motor to see if it will run.
Apr 18, 2014 | Vacuums
Need wire diagram for a 1994 Buick La Sabre, car's not charging and runs real bad on the take off. But with a fully charged battery car runs good.
You do not need the whole wiring diagram mate. Just sort out the charging system for now and worry about the diagram later.
Sep 27, 2011 | 1994 Buick LeSabre
On a 12 lead generator to achieve 480volts. would i have to tie 4 -7 5-8 6-9. 10 11 12 to neutral. and 1 2 3 are line leads. i can get 240 volts from my center taps, for my regulator. cause line to...
The terminals you listed are correct.
T4 -T7 mated
T5 -T8 mated
T6 -T9 mated
10, 11, 12 combined connection
L1, L2, & L3 = output / line leads
However you should have 277 VAC line to ground and 480 VAC Line to line (Across any 2 phases)
So terminals 1, 2 or 3 to ground should be 277 VAC (L1 L2 or L3)
1-2 or 1-3 = 480 VAC
any combination of
1 , 2, or 3 to each other = 480 VAC
As a "generator man" with 19 solutions one being "You might have to sting it" you should know this and be able to use the diagram on the power head to get your desired voltages unless the wiring data plate is missing. I have had to dial in voltage regulators when switching between 240 and 480 to prevent automatic shut downs from over / under voltage.
Kelly
Sep 18, 2011 | Electrical Supplies
Need the electrical wiring diagram for 2005 suzuki xl-7
try this site mate :
http://www.freeautorepairmanualz.com/free-download-user-manual-volkswagen-wiring-diagram/
Jul 12, 2009 | 2005 Suzuki XL-7
Tools & Hardware - Others Logo
51 people viewed this question
Top Huth Manufacturing Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Huth Manufacturing Tool and Hardware - Other Expert? Answer questions, earn points and help others
