Question about Electrolux Dryers
Affinity lafw3511kbo Door is loose and doesn't close right. What could be the problem?
  • DAVE SISCO
    DAVE SISCO Nov 20, 2013
    We have to lift up on it a little to close it properly.
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Check the screws on the hinges
Posted on Nov 23, 2013
Frigidaire affinity door sag
Good Afternoon Mr. T,
I understand that you are having trouble with your Frigidaire Affinity dryer and the door sagging, making it difficult to close and latch the door. I suggest contacting your local authorized technician for assistance with this. They should be able to realign the door without any complications. Hope this is helpful.
-Best Regards-
WP
Mar 12, 2014 | Frigidaire Dryers
Door open message when door is closed
the switch or button that the door pushes up against might be bad you can check this by holding in the button and turn on the dryer if it work than the door is loose if not you need to replace the door switch
Nov 17, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Door lock sensor on affinity washer
It sounds like the entire door latch assembly needs to be replaced. The sensor inside is no longer communicating correctly with the main control board.
Aug 29, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000 installed new door switch now says cd
The main control board thinks the door switch circuit is "open" - you would need a professional to . Is the loading door closed? No, close the door. Yes, go to step (2). 2. Disconnect the plug from J2 on the Main Control Board and check for continuity between the pins in the plug. Open, check the door strike. If good, replace the door switch assembly. Closed, replace the Main Control Board.
Aug 22, 2012 | Frigidaire Affinity ATF7000E Front Load...
Door on my frigidaire affinity wont stay close
you are going to have to replace the door catches on the unit in order to keep your door closed
Oct 09, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Door sags and is out of alignment. Do I tighten screws?
If there are any screws right where the door connects then they shouldnt be loose. If you can lift the door up and then close it you probally just have a couple of screws loose LOL! If not then you might have broke the pin inside the door. Either way it should be fixed before you have water damage. Hope it helps let me know what happens. Thanks
Dec 22, 2010 | Frigidaire Affinity ATF7000E Front Load...
My affinity washer will not close to start a cycle. the buzzer goes off and i get the code "dr" but it seems to close fine
Have a service technician test the sensor in the door jam that senses when the door is closed (this is signaled by the electronic lock).
Dec 14, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
62 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
