Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Repair manual for ''designer habitat 2400w cyclonic cylinder vacuum ''
Fagor gas heater gives me a F1 And F3 error
Posted on Nov 19, 2013
What is water consevation
My understanding of the term addresses the pollution and contamination of the waters especially relating to the water we drink.We also have to think about water being habitat for all kinds of beings.
Aug 02, 2016 | Water Water Heaters
Model # bth199100 low igniter current
Usually requires igniter replacement.
Here is a link to the troubleshooting page - says call service but details possible remedys...
Smith Vertex 100 Power Vent DV Series 120 Instruction Manual Fault And...
Jan 08, 2015 | AO Smith A.o. Smith Bth-199 Commercial...
Leaking drain faucet
turn off gas. turn off water. drain water heater by connecting garden hose to drain valve and place discharge end somewhere that that will safely handle the water.(sink, outside,floor drain). lift temp. relief valve to allow air into the tank so a vacuum doesn't prevent draining. carefully remove the leaking valve by using a pipe wrench. counterclockwise to loosen. there may be a little water left in the bottom of the tank, so be ready with a wet vac. buy a new valve at your local hardware store, along with a roll of teflon tape. wrap the teflon tape around the threads in a clockwise rotation. don't use more than three or four wraps. replace the valve by turning in a clockwise rotation. tighten till snug. don't overtighten! if it still leaks a bit at the threads, you can tighten a bit more.
Mar 09, 2014 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-gas-water-heater.pdf
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-electrical-connection.pdf
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
http://www.amazon.com/dp/B003AU0Z48/?tag=waterheaterti-20
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Add a comment and say what you discover
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
I have a rheem power vent 21vp75e-1 it ignites the burner for couple of seconds and shuts off and retry to ignite into a lock out I wire jump the vacuum switch and it works properly than i replace the...
Before calling service technician, read manual for troubleshooting and yearly maintenance requirements.
Open following links to identify same-similar product and download manual.
Once you have product showing on page, click 'specs-docs' tab to see use-and-care manual.
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
http://globalimageserver.com/fetchDocument.aspx?id=c0471d58-5e59-4be6-96f7-68361b8fb515
Rheem site loads slow, and some manuals never load.
Typical power vent manual:
http://waterheatertimer.org/pdf/Rheem-power-vent-manual.pdf
I believe the 21VP is older and Rheem does not show older manuals, but manuals are generally generic enough to help greatly. Year of manufacture show as second and third digit of serial number.
Lockout condition requires service technician and part replacement, or call Rheem and have them send part.
I found one link that talks about FV lockout that may or may not pertain to your issue:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
Apr 19, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pump leaks
Found the parts needed on eBay.
Jan 20, 2010 | Hydro Systems ERI6060ACO Designer Series...
I have a leak in my water heater coming from around one of the legs. If I shut off the water, the leak seems to change to one of the other legs. Is there some sort of new pan that I can buy or a part that...
Sorry, Sam it sounds like the water heater is defective, unless you can find a leaking connection. It sounds like you have a leak in the heater proper. The reason the leak moves is that, when you isolated the water, it cooled and a slight vacuum is pulled, and the water picked a different course (probably). Before you change the heater out, look at the threaded connections for leakage. Check the inlet and outlet lines, boiler drain valve, pressure relief, and any other threaded connections that you may have. If you find any leakers, you can repair them with wrenches and teflon tape. If no leaks are found at any of the threaded connections, the assumption is that the tank has developed a pinhole leak. They generally are at the bottom 1/3 of the tank. What you can do in the future is to either buy the kind of hetaer that is designed to stir up and remove the scale and sediment in the bottom of your heater, or to manually flush your heater from time to time.
Best regards, --W/D--
Aug 12, 2009 | Water Heaters
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
74 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
