Question about Microwave Ovens
Compatible installation I would like to know what microwave overs are available today to do a simple replacement . I would like to remove the old nonfunctional one and slide the new one in using the same mounting screws, vents etc. I don't want to do any drilling, cutting, moving things and so in.
  • Greg Nov 18, 2013
    It is an Amana Radarange MVH220E/01. What newer models will fit the existing mounting scheme.
  • Greg Nov 18, 2013
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
You would need a new microwave with the same locations for the vents, mounting screws, etc. Since you didn't say what make and model the old one is, I'm afraid no one can give you a list of matches.
Posted on Nov 18, 2013
4 Suggested Answers
  • 43 Answers
SOURCE: Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Posted on Feb 01, 2008
SOURCE: How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Posted on Mar 12, 2009
SOURCE: Microwave installation
I'm a kitchen remodeler, and I've seen this problem with Kenmores (so it probably exists with some other brands too. The ones I have seen have the typical bolts through the top, but there's more. The flat mounting plate on the wall has an protruding piece that fits well into the body of the microwave when the unit is slid into place. It has a threaded hole in the end of the extension, and the sheet metal screw or bolt that goes into this is causing your anguish. To access this, you must remove the top front louvers (maybe some other trim plates as well). You'll eventually find the bolt that unscrews with a horizontal screwdriver. Chris Harrison, Richmond Refacing.
Posted on Apr 05, 2009
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Replace door
If you're replacing the entire door, this is a very simple process that only requires you to open the door all the way and lift straight up at the hinges. The door lifts off the hinge pins, and the new one can be reinstalled by aligning it back on the hinge pins. (You may have to remove the hinges from the old door and install them on the new one on some models). NOTE: In some cases you may have remove the upper grille guard to accommodate lifting the door. The mounting screws for the guard on located across the top of the oven. If you only need to replace the door handle, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 26, 2011 | GE Spacemaker JVM1540 Microwave Oven
GE Spacemaker Microwave, Model #JVM1540SN1SS, buttons don't work
The membrane keypad has failed.
The keypad itself is not available as a separate part, so the control panel frame with keypad would have to be replaced.
This is actually a pretty simple DIY job.
You can part number WB56X10826 from the Pros here for $114.62 plus shipping (that compares to $166.50 from GE!).
You can also find helpful exploded view diagrams at that link.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then disconnect your keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
May 27, 2010 | GE Microwave Ovens
I am trying to remove an old Amana MICROWAVE over the range microwave. have remove the three screws from the cabinet above but it still is hung up on something. It will move a little up and down asa well...
I'm not positive on old Amanas, but some very old units slid out of the main case. The main case was installed and the cooking unit slid inside the case. There were two screws in front that released a connecting device at the rear. Check at the front top corners for a screw that may disconnect this. I have also seen extra screws added through the cabinet to the side, that shouldn't have been put there, that are screwed through the side of the main case. Good luck I am available this evening for further assistance, just let me know. Have a Merry Christmas.
Dec 24, 2009 | Amana MVH210W Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
The turntable does not turn. How do I change the
The turntable motor can be replaced by following these steps:
1. Unplug microwave.
2. Open oven door and remove glass tray and carousel ring.
3. Locate and remove the screws holding the bottom panel (under the microwave) in place. With the screws removed, the bottom panel should open.
4. Disconnect the connector plug from the turntable motor.
5. Reach inside the oven and remove the coupler. This is the small plastic piece that the center of the glass tray sits on. You may have to gently pry up with a flat screwdriver to get it to come loose.
6. With the coupler removed, loosen the mounting screw(s) to the motor and it should easily come out from under the oven.
7. Install new motor in the reverse order of the steps I just provided.
This is a very simple repair. Ironically, I just replaced mine today. If you have any questions, or require additional assistance, please let me know. I hope this help you.
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
We have an LG over the range microwave and boiling a pot of water on the stove apparently shorted out the key pad. The numbers don't work and the vent and light buttons work intermittently. Note that this...
We have an LG LMVM2075SB over the stove microwave that we purchased in December, 2007. A few weeks ago, several of the positions on the touchpad stopped working.
I assumed that the problem involved the touchpad itself. I ordered a new one (Part number MFM37134802 - $25.30 plus shipping), and we installed it today. This solved the problem.
J. Adams,Alabama
The installation was not simple. The door has to be removed and disassembled to enable you to get to the connector that connects the touchpad with a circuit board. We heated the old touchpad with a hair dryer and pulled it off (after disconnecting the connector). The new touchpad comes with an adhesive backing. You have to be very careful in placing it because the adhesive is very strong. The touchpad fits in an identation, so the placement of the new one must be perfect.
Failure of the touchpads on these LG models seems to be a common problem. It sounds like a design problem.
Jul 07, 2009 | LG Microwave Ovens
Switch for stovetop light on Goldstar over-the-range microwave
This is caused by a failure in the Sharp solid state relay "chip" (S201DH2). The newer pin-compatible versions don't seem to suffer this weakness. I used the R31HD2 (http://document.sharpsma.com/files/pr21hd22_e.pdf) which should still be available in the US for less than $10 delivered from Mouser or similar retail friendly parts houses.
A simple repair for someone with the tools and basic skills for removing and replacing a chip that is soldered to a printed circuit board. If you lack either of these, better to order a replacement board or have it serviced professionally.
Dec 11, 2008 | Goldstar Microwave Ovens
How to replace a 2000 HR Endeavor "over the range microwave oven"
It sounds like you may have a bad keypad or (hopefully) a simple door switch failure.
When you press Start, if it does not beep, then either the door open switch is bad (not very likely) or its mount is bad, or your membrane keypad is failing.
If it beeps when press Start, and your fan and inside light come on and it counts down, but the turntable doesn't turn and it doesn't cook, then you have a bad secondary interlock (lower door switch with white and gray wires) or its mount is broken or loose.
You can try gently pushing up and down on the door while trying to hit Start. That will sometimes make it try to work.
For this model, neither the control panel frame with keypad nor the separate membrane key sheet is is available, but the key sheet from a different colored model may still be available. I can check into that further if you want.
Door switches are pretty easy to get. They are often held in place by a little tab on the underside of the mount. That can be hard to reach, but not too bad if you're careful.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have the service manual for this model and I can e-mail to you.
If you'd like us to install the keypad, we can do it for $39.95 plus parts.
Please feel free to contact me directly if you need more help.
Please contact me directly and I'll also send you installation info on several Sharp models. That should give you enough info in case you decide to remove it.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 25, 2008 | Sharp R-1405 / R-140 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
