Question about Zebra Z4Mplus Label Printer
Is an Inkjet printer supports Zebra Programming language (ZPL) to print labels or pages.?
I used to print labels using Zebra GX430t printer as I have ZPL command used in my software. Now I have Inkjet printer, and same software is not printing label on this type of printer. Can someone please tell me that, is the InkJet printers supports ZPL (Zebra Programming Language) or not?.
2 Suggested Answers
bartech9
  • 155 Answers
SOURCE: Printing on a continous teffeta label using zebra S4M zpl printer
Con un windows driver, sí imprime? Intenta reiniciar la impresora con los parametros de fabrica. La impresora tiene zpl o epl firmware?
Roberto Martinez
Posted on Oct 06, 2009
Hi Dear All, My printer is not printing ZPL
Only Zebra printers use and print ZPL. ZPL =Zebra Programming Language. Other printers cannot intrepret ZPL.
Aug 13, 2013 | Zebra RW220 PRINTER 2" DT RUGGED MOBILE...
I am trying to install a lp 2824 plus zebra label printer and i need to know whether to select epl or zpl?
You should probably select ZPL, but that depends on which program you will use together with the printer.
Jun 20, 2011 | Zebra LP 2824 Printer
What is the difference between the Zebra LP 2844 Thermal Printer and the Zebra LP2844Z?
lp2844 use programming languages EPL2, Line Mode, lp2844 use ZPL II, ZPL (Zebra languages), both are Direct Thermal (don't use ribbon), not Thermal-Tranfer (use ribbon).
Nov 17, 2010 | Zebra LP 2844 Thermal Label Printer
I have two zebra printers 140XIIII Plus. Printing labels from the same database file. One prints the characters in boold the other one doesn't. Is this because of the driver? How can I make the two...
You would have to look at the Zebra programming language(ZPL) being sent to the printer. Are you writing your own code or using a labeling software package ? The printer driver will convert to ZPL if using a labeling software package. You didn't say if the two printers are connected to the same PC or two PC's. Check your formats if two PC's. Something else is going on if both printers are connected to the same PC.
Apr 27, 2010 | Zebra 140XiIIIPlus Label Printer
Ido not have any problem if I print label using Zebra. I wrote codes on Visual Basic 6 to print label using Datamax printer conneccted parallel port with command L to start. The printer printed the text...
Do you have Zebra emulation firmware installed? If not, your printer will not understand the command language that you are sending to it. Datamax has its own language and you will need a branch in your code to support that if the printer does not work with ZPL.
Jan 14, 2010 | Datamax Prodigy Plus Thermal Printer
How do i input text with this printer
Just like you would any printer. You could use word but word by default is set for a 8.5x11 full size paper so it must be configuared under file, page setup. Your label size gets entered and margins are zeroed out, or use the free label software called zebra designer which can be downloaded from this link.
http://www.zebra.com/id/zebra/na/en/index/products/software/label_design_software/zebradesignerpro/zebradesigner.html
Oct 05, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Roberto Martinez
Jun 30, 2009 | Zebra S4M Thermal Label Printer
Currently have a TLP2742 duplicator which prints barcode and text. Need to alter this to just print the text. how do i do it?
Do you know if you are using a label software program to design the label or just ZPL (which is Zebra Programming Language) code direct to the printer? If it is software, then you can open that label design software file and remove the barcode. If it is ZPL, then you need to remove it from the code. I can help with this if you can email me the code.
hilster1968@gmail.com
Jun 26, 2009 | Zebra Eltron TLP 2742 Thermal Label...
S4M doesn´t print
The S4M comes with either EPL or ZPL programming language installed. (installed at factory) The S600 is a ZPL only printer. Check that you have correctly specified the S4M as a ZPL printer. Print a config label to check. If it is set as an EPL printer contact your supplier and ask him to download the correct programming language. It should only take a competent engineer about ten minutes (If he knows what he is doing)
Jan 20, 2009 | Zebra S4M Thermal Label Printer
Can we use any commaon laguage for all Zebra printer.
Can you explain what is is you are trying to print on the label?
May 22, 2008 | Zebra LP 2844 Thermal Printer
Zebra Z4Mplus Label Printer Logo
27 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
