Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Image went out and now i see small blur in the middle
My image went out on my Panasonic PT-53TW53 except in the middle there is some of the image in the middle of the screen but its very hard to see it, the tv is about 3 years old what can this be?
  • yoboyd06 Oct 10, 2007
    the blur is from top to bottom I believe, I was sitting on the floor pressing the buttons when i noticed the blur and it seemed as if it was only on the lower part of the TV but when I stood up I noticed that it went all the way up, it kind of looked as if it was moving am not sure.
    Genius:
  • 1,153 Answers
Does the blur goes across set? Or is it round in the middle?
Posted on Oct 08, 2007
SOURCE:
Panasonic pt-53tw53 location of my stk chip
my tv panasonic PT-53TW53G turn on red light on tv no pictur on sound
Jan 06, 2012 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53 color suddenly seperation went way off.
You can get the convergence repair kit at www.tvrepairworld.com which contains the parts and the CD which has the instructions and the service manual on it. You would need the PT53WX53 convergence kit.
Oct 18, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Shadows and text curved. Double images
The convergence IC's need to be replaced. The generic part # on them is STK392-110. This is not easily done by yourself.
Apr 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Pt-53tw53 tnp2a1h046 schematics
Cheap IC's = open resistor
Replace with X 480293 Kit Use IC's from kit to save $$.......T.
Mar 15, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53
more than likely its your convergence amplifier ICs and if you can solder you can repair it yourself really easy.
Jan 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pt-53tw53g March 2004
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Blurred image on panasonic tc21p50r
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 09, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Blurr picture and very red faces
Open the front cover of the tv and try to adjust the screen adjustment thruogh the screen variable resistor.
Nov 17, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
