Question about Comdial Impact Telephone
Voicemail Flashing with a Call S40
Voicemail is not accessable due to a call s40 in the lcd screen.
How do I replace the LCD screen on a Sony cybershot dsc S930 camera.
I am not sure about the specific brand. Open the case by removing screws (usually 5-6). The LCD screen is immediately accessible. Lift it carefully and trace the ribbon connector. Lift the small flap in the connector carefully and pull out the ribbon cable. Replace it in the reverse order.
Jan 03, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
DCS-S40 White LCD screen whats up?
i posted a pic i edited.
this is a hardware issue that really has no perm fix. but is easily fixable with my pic.
Oct 01, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony cybershot dsc-s40 lcd screen is all white
okay the lcd being white means its replacment of lcd time and not the camersa itself. But to rule that out try taking a pic if you cannot you might got a shutter issue as well.
Thanks hope the information helped
Sep 17, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
How to reset sony dsc-s40 camers
I read that you hold in the three outer buttons on the screen side of the camera, which would be the MENU, LCD power, and Delete buttons, while turning the camera on. The LCD and Delete buttons are identified by symbols, not hard to recognize.
Feb 26, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank screen Sony dsc s40
I have sent the solution to you. But take care of your camera if you are going to open yourself. I am not responsible for any damage.
Dec 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank Screen
I have been facing the same problem with same model and this is permanent problem it seems with this model (Sony Cybershot DSC S40). It causes because of the following:
SYMPTOMS
LCD display is either blank or WHITE. When the cabinet is opened or LCD flexible cable is
touched, the symptom disappears. This is caused by connection defect or poor contact between connector and LCD flex cable due to the pressure or stress created by the rib in the front cabinet
to the connector.
Send me a email and I shall send you the solution (two files) received from Sony authorized person. You have to open the camera to solve this. Do not open the camera . Just get the idea about where the problem is. I never opened the camera even after seeing this solution 2 yrs back. However, I have a plan for going to service centre with this solution. I hope they can open the camera and solve this. But not getting time to go there in service centre.
I used the following temporary solution and it works to get LCD in its normal condition:
LCD looks like a rectangle is not it? Hold the camera in its normal position as you are going to take a picture (camera is switched on and you are not seeing anything in the LCD, which looks white or dull). Now GENTLY PRESS by the thumb of your right hand at a place near to LCD at the BOTTOM RIGHT CORNER of the rectangle (remember not on the LCD (rectangle) but just outside of it) until you see the normal colour of your LCD. Do few times starting with less pressure and then slightly increase it untill you see a normal LCD. I have been following this procedure for the last 2 yrs and not feeling to go for serving. (This solution I found in a forum only).
(mondal_ashok (at) rediffmail.com
Nov 16, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony digital camera dsc s40
code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Jan 13, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank screen - I don't think it's E18
Try and clean the LCD connector _flexible connectors. If you are able to see the dark picture- The back light panel is defective or improper contact. If the picture is perfect in the PC when you download,,then the LCD may be defective For LCD pl.e mail me...may be we can give a new one.
Dec 02, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Comdial Impact Telephone Logo
Top Comdial Lands Phones Experts
george  peters
george peters
k24674
Tom Chichester
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
