Question about Coleman Electrical Supplies
Charging Coleman 5327-750 lantern
How long should it be plugged in to charge and how often should this be done if it is not used?
joboo1
  • 257 Answers
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Posted on Mar 16, 2009
sal_kh_sab
  • 98 Answers
SOURCE: coleman powermate 1850 charge time
i advice you not to keep it plugged in too long...just about enough to get it workin....
:had a bad over-charge axcident..
Posted on Oct 15, 2009
SOURCE: how to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Posted on Nov 06, 2009
  • 973 Answers
SOURCE: lantern doesn't charge using the hand crank dynamo
You most likely need a new battery, you can purchase one from Black and Decker, here is the link
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=68217&tid=15945
Posted on Jun 18, 2010
CarlGlas
  • 283 Answers
SOURCE: Coleman rechargeable lantern: Charged overnight -
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
Posted on Jul 21, 2010
How to change the battery for my 4345 coleman lanterne
There are two adapters for that lantern; one for the house and one for 12volt. You simply connect one of the adapters and it will power the lamp and also charge it. Those two adapters came with the lamp; if you don't have them you can contact Coleman to purchase replacements.
Jul 29, 2014 | Coleman 8D Family Size LED Lantern -...
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours http://www.coleman.com/Parts/100/parts-lanterns/5317-702/remote-control-pack-away-family-size-lantern# then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
Charge Time for 5312 Lantern Battery?
Charge time is 18hrs. If you left it on and it was flat, imediately charge for 40hrs.
heres the manual.
http://r1.coleman.com/Manuals/5312R.pdf
Feb 12, 2014 | Coleman Retro Rechargeable Battery Powered...
Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Nov 22, 2011 | Camping, Backpacking & Hiking
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
My lantern/fan/radio doesn't work when its not plugged in?
The battery probably isn't taking a charge anymore because it needs to be replaced. These batteries will sometimes last a few years but then a replacement is needed and they will likely run like new. You can check out http://www.batteryinternational.com/lantern-battery.html to find a replacement battery, or you can call 1-877-28-BATTERY if you are having difficulting finding the battery you need.
Jun 18, 2009 | Coleman Lantern Fan Radio (841.321) AM/FM
Coleman lantern/fan/radio won't take a charge any more.
Yes there is, you can check out http://www.batteryinternational.com/lantern-battery.html to find a replacement, or call 1-877-28-BATTERY if you're having difficulty finding the battery you need. Hope that helps.
Jun 14, 2009 | Coleman Lantern Fan Radio (841.321) AM/FM
Hi With the rechargeable lanterns that charge by electric or car charger what do you put the lantern on to charge turn it off or put it on on or dc?
You connect the charger to the lamp and plug the charger into an AC outlet. Having the lamp on will increase charge time. The charger does not appear to accept feedback from the battery so it depends on you to disconnect it when charge is complete.
Jan 28, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Electrical Supplies Logo
136 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
