Code honor 3. how do i get the video display to work on my PC that has windows XP professional?
  • 27,725 Answers
If you mean ERROR CODE 3
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Since you cant get a screen you might have to enter safe mode to check the error code however
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
Posted on Nov 18, 2013
2 Suggested Answers
Nitin_Master
  • 846 Answers
SOURCE: i have my desktop PC
http://support.asus.com/download/download.aspx?SLanguage=en-us go to the above site,select your operating system,and download the drivers...............
Posted on Oct 31, 2010
Testimonial: "hey... thank you very much// that was quite much helpful to me.. thanks once again../"
Code of honor 2 black screen
Try updating your video graphics drivers to the latest version.
Jul 01, 2014 | Microsoft Code of Honor 1 & 2 - Windows
I lost my key for xp 3
Here's a video null suggested as a solution to your problem from YouTube:
How to Reset Windows 7/ Vista/ XP Password, Free EasyWay. (USB)
Jan 14, 2013 | Microsoft Windows XP Professional SP3 Full...
My dell optiplex gx 260 has a blank screen when I turn it on. The windows xp professional screen comes up then when it goes to where the desktop should show up all I get is a gray screen
1. From reading your issue it seems the video card is defective.
2. If you have received the Windows XP splash screen and then the monitor displays a gray screen then only two things have happened here your drivers are corrupt for the video card or the video card itself has failed.
3. Suggestion: install a new video card compatible with Windows XP.
4. Most Dell Optiplex desktops have the video graphics card integrated to the the mother board.
Oct 14, 2011 | Dell OptiPlex GX260 PC Desktop
Is that this card(canopus acedvio pro version) any problem with windows 7
MPN 770-10116-900
Adapter Type Video Capture
Interface with Host PCI
Video Input Composite Video • i.Link (IEEE1394)
Video Output Composite Video
Platform PC • Mac
Hey no problem....It is best for Video capture...the datails are this.... i still useing it.........
Technical Features
Audio Support Stereo
System Requirements
Operating System Apple MacOS 9.x or later • Microsoft Windows 2000• Microsoft Windows XP Home Edition • Microsoft Windows XP Professional
Warranty 3 Years
Included Accessories 1 x Firewire (IEEE1394) Cable • Composite to S-Video Cable
Nov 18, 2010 | Canopus ACEDVio/EDIUS Pro 3 Bundle...
I dont have code28
Microsoft Help and Support says that "Code 28 (The drivers for this device are not installed)" appears when the Windows Sound System Compatible Driver for the Windows 2000 operating system is deleted upon the upgrade to Windows XP. It's possible to repair this code.
Instructions
1 Click on "Start."
2 On the "Start" menu, click on "Control Panel."
3 In the "Control Panel" folder, click on "Performance and Maintenance."
4 Click on the "System" folder in the "Performance and Maintenance" folder.
5 Click on the tab titled "Hardware."
6 Click on the box that says "Device Manager."
7 Click on "Sound, Video, and Game Controllers."
8 Right-click on the device that prompts Windows XP to display Code 28 (it should be Windows Sound System Compatible Driver, also called the WDM driver). A drop-down menu will appear.
9 Click on "Update" and an Update Wizard will guide you through the installation of a new device driver, which should stop Code 28 from appearing on Windows XP.
Nov 03, 2010 | Microsoft Windows XP Professional
HOW TO INSTALL MICROSOFT WORD XP
hi
their are two ways to install microsoft word xp into your computer
1st got to official site of microsoft and download the software from their
2nd get a microsoft cd from any of the computer shop and run it on your computer once you install it .it will ask for a activation code type the activation code it would be given on cd cover and you would be able to download the software on your computer .
thanks
techbuddies
Apr 23, 2010 | Microsoft Windows XP Professional for PC
How can i download video controller for my windows xp
if your "video controller" is bad then you need a new motherboard, but if you need a video "driver" then follow these steps
  1. start
  2. control panel
  3. system
  4. hardware
  5. device manager
  6. click on the little plus next to "display adapters"
  7. right click your installed video adapter (onboard or pci card)
  8. update driver
that should work, hope this helps
Mar 26, 2010 | Microsoft Windows XP Professional for PC
PLS CAN I GET A ACTIVATION CODE FOR WINDOWS XP PROFESSIONAL SERVICE PACK 3
If you have a VALID XP license there is no activation code for the service pack.
You download it from Microsoft who will evaluate if you have a legal copy of Windows XP and will install the service pack. If you have a pirate copy they will document it and refuse to install the service pack.
Go to the Microsoft site and have them scan for updates for you.
Dec 08, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
