Question about Dishwashers
Find Serial number on Hoover DDY062 Dishwasher
Dear gents, I face problem in hoover HDW1400 dishwasher machine Error E1 kindly need your support to solve this issue
The E1 error most likely means that the dishwasher identified a slow fill issue. First, make sure that the inlet water connection is not leaking and that the water valve is open. Make sure that the incoming water is as hot as possible from your water heater. (Wash some items by hand first.) Next check the inlet valve and those connections. Check the voltage across the valve to make sure that it can open. (If the valve failed in the closed position, there will be no water in the dishwasher when you open it in the middle of the cycle.)
Next check the float valve to ensure that it is rising and falling properly. If the float is blocked in up position, the washer will assume that it didn't properly fill and stop operating. Check the switch as well to ensure that the signal for the float position is properly being provided to the CCU.
I hope this helps. Unfortunately, I can't find the HDW1400 model number to assist you in obtaining any replacement parts. Please check the model number. If the model number given inside the door of the dishwasher is different than that given above, please add a comment with the full model number of your dishwasher. If your unit is under warranty, contact Hoover directly.
Jun 15, 2015 | Hoover Dishwashers
Hoover DDY-062 dishwasher leaking from safety switch.
Sounds like you need a new safety switch or the installation of it is not good. Is the water level getting too high which would indivate that the system has another problem in letting in too much water.
Sep 21, 2014 | Hoover DDY062 600 mm White Freestanding...
Can I turn the beeper off on the end of the washcycle on the DDY062 Hoover dishwasher. I want to put it on timer delay and dont want to be woken in the middle of the night.
These are the instructions taken directly from the DDY062 manual:
Alarm mute for the PROGRAMME END
The alarm for the programme end may be muted as follows:
IMPORTANT The dishwasher must be ALWAYS off before start this procedure.
1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound).
2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound).
3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on).
4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off).
5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting.
To turn the alarm on again, follow the same procedure.
Jun 21, 2012 | Hoover Dishwashers
Hoover Dishwsher DDY062 user manual
Hi Margaret,
Here's the manual in pdf.
Hope this helps.Thanks!
Dec 14, 2011 | Hoover 24 in. HD83M Free-standing...
Dishwasher has been stored for a few months, we have just connected it back up and switched and error code E4 has come up. What does this mean and how to I rectify it?
E4 means that the dishwasher has a problem with discharging water. Check that the discharge tube is not bent and the siphon is not blocked and the filters are not blocked. Depending on how you stored the dishwasher, check for evidence of rodents or insects building nests in the unit.
The manual for the HD97 is available from Hoover at http://service.hoover.co.uk/manuals/Manuals.aspx?Section=3 . Enter the model number and the link will come up. The manual for the free-standing version does not seem to be available separately.
I hope this helps.
Jun 12, 2011 | Hoover 24 in. HD97E Free-standing...
What year is this Kenmore dishwasher Model # 665.15831791 made?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. This dishwasher was manufactured by Whirlpool. The following link explains how to determine when it was manufactured:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The serial number is usually located somewhere around the door opening. The first two numbers in the serial number identify the WEEK it was manufactured (52 weeks in a year). The second DIGIT in the serial represents the YEAR it was manufactured.
If you have difficulty determining the manufacture date, please post back with your serial number and I will assist you. I hope you find this information helpful.
Mar 29, 2010 | Dishwashers
Question-can I purchase a recovery tank front panel for Hoover Carpet Clean - F5853-900, series 17.9, serial number 069700345408? I can be reached at (304) 243-3788
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=675962
Generic problem for all Vacuums
Posted by dings on Jun 16, 2008
Question-can I purchase a recovery tank front panel for Hoover Carpet Clean - F5853-900, series 17.9, and serial number 069700345408?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the local factory authorized Hoover dealer in your area and they might have a good used part or they may have a new one in stock or they can order it for you if you give them the brand name and model #, serial # or choice #2 is that you can contact the Hoover Factory Parts Dept and they can ship you out one recovery tank front panel for the Hoover Carpet Clean F5853-900 Series 17.9 and serial number #069700345408.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 16, 2008 | Vacuums
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
