Question about Cell Phones
Omal 6000 instructions
Hi , I have omal 6000 saying low battery ,but is also pluged into socket , light in front is flashing , looks like adapter is gone ,could that be an option?
5 Suggested Answers
  • 21 Answers
SOURCE: IBM R32- battery light problem
usually when the charging light blinks and wont change to solid green it means the battery is dead.
solution is to buy a new battery
Posted on Dec 08, 2007
SOURCE: supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Posted on Jan 20, 2008
olwork
  • 237 Answers
SOURCE: Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Posted on Jun 29, 2009
Lacerz
  • 92 Answers
SOURCE: acer aspire 5315 batt problem
Please run this unit on A/C only and see if it powers up like that. If it does not, then the A/C adapter is faulty and thus cannot charge your battery.
Service the battery by hitting it flat onto your hand palm or onto the back of your shoe and retry to see if it is charging.
Posted on Jun 01, 2010
My acer 4720z cannot turn on anymore and the adapter pluged correctly but no power enter the system
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
May 17, 2013 | Computers & Internet
No power at all
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 12, 2013 | HEWLETT-PACKARD HP Mini-Notebook...
Can't get the laptop to come on.
Mar 25, 2013 | Gateway M305CRV Notebook
My laptop want power on
Feb 19, 2013 | Samsung RV515-A01 15.6 Laptop X2 1.6GHz...
Unit will not power up
Jan 12, 2013 | Dell Inspiron 6000 Notebook
Have a sony vaio the wont turn on, nor will any lights come on.
Dec 01, 2012 | Sony VAIO EB Series Notebook
Toshiba a135-s4407 quit charging when pluged in, replaced battery and charger is putting out 17 volt 4.75amp
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This model Toshiba may have a power socket that plugs onto the motherboard.
This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Dec 21, 2010 | Toshiba Satellite A135-S4407 Notebook
My bros e627 when he plugs it in to charge it sais pluged in but not charging with ornage bliking lighthelp?
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Dec 25, 2009 | Sharp Actius AV18 Notebook
Have a gateway M465-E with power issues. Low
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 26, 2009 | Gateway M465-E Notebook
Bad AC connection, how do I fix it myself? soder the connection?
The AC connection is at the mains wall socket. I presume you mean the DC plug that plugs into the laptop or the DC socket on the laptop.
Oct 28, 2009 | Dell Inspiron 6000 Notebook
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
