Question about Clay Adams Science & Laboratory
Centrifuge has no power, won't open, specimen inside. How can I release the lid
5 Suggested Answers
  • 113 Answers
SOURCE: gas lid will not release
try to adjust ur cable linkage at the switch in the car or u may have to replace the cable
Posted on Jun 16, 2008
  • 3 Answers
SOURCE: Pontiac Astez lid will not open
Adding to the guest's comment, mine did the same thing too, taking the fuse out will reset the computer system.
Although it works, it's only a temporary fix. It's eventually going to get worse. Turns out Azteks are notorious for the Body Control Module going out.
I just went through a nightmare with mine and finally got it replaced.
It should resolve most the problems as it did with mine, but now ours is blowing fuses and the radio has locked itself thinking it's been stolen (and so a new journey begins)
Good luck, friend...I feel your pain!
Posted on Sep 06, 2008
  • 4 Answers
SOURCE: Driver's door won't open inside
Hey, You need to remove the panel otherwise u can't reattach the metal sticks that move the locks, but i think it's hard to remove it in a closed posision when u don't brake it
Posted on May 16, 2011
SOURCE: lid lock won't release on Cabrio washer
hey there have you tryed un plugging it the pluggin it back in
Posted on Nov 18, 2012
I want to get in the trunk from the backseat of my 2006 Saturn ion, how do I go about that?
You can fold either side of the rear seatback down for more cargo space.
To lower the rear seatback, follow these steps:
Open the trunk and pull one or both of the small handles located in the center of the trunk.
Once the handle is pulled, the seatback can be pushed open through the trunk, or pulled open from the inside of the vehicle.
Sorry ,but you need the trunk open ! What's wrong with your's ? loose your key . trunk release inside the vehicle doesn't work .
Luggage Compartment
Your best bet , have a qualified repair shop check it out . May have DTC'S diagnostic trouble codes stored .
DTC B3267: Trunk Release Output Circuit Low
DTC B3268: Trunk Release Output Circuit High
The rear compartment release circuit consists of the following:
• The intergrated body control module (IBCM) fuse
• The rear compartment lid release relay
• The rear compartment lid lock release actuator
• The rear compartment lid release switch
• The cargo lamp/trunk ajar switch
The rear compartment release circuit operates as follows. Battery positive voltage is applied at all times to the rear compartment lid release relay. The rear compartment lid release relay is energized by either depressing the rear compartment lid release switch, or when the IBCM receives a rear compartment release signal from a key fob. The IBCM then provides a path to ground on the rear compartment lid release relay control circuit, energizing the rear compartment lid release relay. When the rear compartment lid release relay is energized, battery positive voltage is supplied to the rear compartment lid lock release actuator causing the actuator to energize releasing the rear compartment lid. The rear compartment may be released with the dash mounted rear compartment release switch. The ignition must be in the OFF or ACCESSORY positions for the rear compartment to be released with a keyless entry transmitter fob (RFA). The rear compartment may also be released by an OnStar commanded using RFA functionality.
Dec 28, 2017 | Saturn Cars & Trucks
Can open my trunk doesn't work with remote or from inside of glove compartment thanks 2005 ssr chevorlet
Rear Compartment Lid
The rear compartment lid can be opened by operating the rear compartment lid release switch, located on the instrument panel, or by using the manual release located on the rear compartment lid. Battery voltage is supplied to the rear compartment lid release relay through the Main Power fuse. The roof and door module (RDM) receives the rear compartment lid release request via the rear compartment lid release switch signal circuit. The RDM grounds the rear compartment lid release relay coil when a release input is received through the instrument panel (I/P) switch. Grounding the coil causes the rear compartment lid release relay to energize, providing power to the rear compartment lid latch assembly through the rear compartment lid release actuator supply voltage circuit.
As an alternate method of operating the rear compartment, an emergency release handle is accessible from within the rear compartment. When the handle is slightly pulled, it will provide a ground for the bed cover release relay which will cause the actuator to operate and open the rear compartment lid. If the handle is pulled further, it will mechanically open the lid, so even if the battery is discharged or there is an electrical concern, the emergency release handle will mechanically open the lid.
Jan 01, 2017 | Cars & Trucks
Where is the inside trunk release on a 2000 vw beetle. Trunk lid will not open with key, fob, or door release.
Trunk won open even with manual release http://newbeetle.org/forums/new-beetle-convertible/54170-trunk-wont-open-even-manual-release.html there is good info here C24OF
Dec 21, 2016 | 2000 Volkswagen Beetle
Eppendorf Centrifuge 5430R lid does not open after pushing the 'Open' button in front display
Probably too late now but there is usually a small hole in the centrifuge where a thin shafts can be inserted to manually disengage the locking system.
Apr 19, 2014 | Science & Laboratory
Can't open centrifuge
It the rotor cover will not release normally, look for a small white plastic button underneath the front of the unit. You will need a small flathead screwdriver or tweezers to pop it out. The plug is attached to a string that threads up to the locking mechanism, and can be used as an emergency lid release.
Aug 07, 2013 | Eppendorf centrifuge microcentrifuge 5414...
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
Mar 10, 2017 | 2007 Toyota Camry
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
I have an IBM Selectric III that has been stored for a couple of years. Before storage it worked fine, but now it just idles when powered up and nothing operates. I assume this means it needs lubrication....
Typically a machine that has been out of use, but was previously working may just need some lubrication on the motor centrifugal clutch assembly, but the entire machine probably would need lubrication also. You can first try to hand cycle the machine by grabbing the shaft that the carrier travels on and rotating it towards the (top to rear) rotation. This shaft rotates on revolution per print cycle and at rest the slot is slightly towards the rear of the machine. If you must lubricate the machine, then remove the cover. Lift the lid, place each hand of platen knobs and with thumbs, push down on release latches, after platen is out of machine, reach inside left and right cover and release the top cover latches and pull the cover straight UP to remove. Use 10 weight oil on motor bushings and centrifugal clutch hub (motor shaft).
Nov 08, 2009 | IBM Office Equipment & Supplies
Fuel Filler Lid won't open
it sounds like you have a broken cable that connects from the inside of the car to the release of the gas tank. now the other release ( you said the book says is in the trunk on the lefthand-side ) it is probably under the lining of the trunk because most of them are not in plan sight for you to see.
Mar 24, 2009 | Hyundai Motor 2003 Sonata
Science & Laboratory Logo
519 people viewed this question
Top Clay Adams Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Clay Adams Science and Laboratory Expert? Answer questions, earn points and help others
