Error while sending message to sc print a
My printer is connected with the help of a ethernet cable. Iam using Window XP for printing. When i enable Local Area Connection their is a pop sign on the Local Area Connection Symbol and when i connect the printer with SC-PRINT A its fine. But when i give the command of printing then tne message appears. What should I do? Also can you please give me your Phone number so that i could finish this print job. You know lots and lots of time is wasted on this printer and can you please give me the contact no. of any engineer in Dharamshala H.P So that i could finish my work faster. Thank You
    New Friend:
    Problem Solver:
  • 8 Answers
Try installing the printer with a USB cable first (disconnect the LAN CABLE FIRST) and do a normal installation. Check all functions of the printer and then do a LAN printer install by going to "install or add a new printer on the control panel and then follow the instructions for adding the printer via LAN or wireless if it does support that function. I think you did the initial install backwards (LAN first instead of USB) and when you think you're done, update any software that might be available from the manufacturers site, THE ACTUAL MANUFACTURER not any other site that offers the update!) Like CNET OR FIXYA OR WHATEVER) GO DIRECTLY TO THE SITE, e.g., Canon, Epson, ETC..)
Posted on Nov 18, 2013
SOURCE: can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Posted on Sep 29, 2007
SOURCE: DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
I unplugged the printer and plugged it back in and it started working and has been working since.
Posted on Mar 24, 2008
SOURCE: ZQL420+ is printeing an extra blank label with each good label.
Check if you have " send Form Feed after each file" is enabled (or yes) in your print queue
Posted on Dec 11, 2008
  • 95 Answers
SOURCE: My Ricoh Afficio 2232C doesn't print and it gives me this message
A 440-1 is a black drum motor lock. The waste toner in the black pcu is backed up, more then likley. It is not easy to fix. You could replace the black pcu but it will happen again. The usual problem is oil in the main waste toner system. It clumps up the toner and clogs the part where all the waste toner comes together for entry into the waste toner bottle.
Posted on May 26, 2009
angelus316
  • 41 Answers
SOURCE: HP Laserjet 2200dn print spooler unable to connect
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
Posted on May 28, 2009
Printer not connected to cmmputer
All cables can fail! Have you tried changing the connecting cable for a twin?
Go to Start>Control Panel>Printers and Faxes
In the new window, select the Hardware tab and Device Manager and select Device
Manager button. Near the bottom of the list is Ports, double click to open. One should
say 'Printer Port (LPT1)
2x Click on that and a new window opens 'Printer Port Properties'
It should say 'The printer port is working normally' and at the bottom it should say 'Use
this device (enable)
If it isn't, then Enable it. Then select the 'Trouble shooting' option.
All being well, eventually click OK and close all windows.
Go to Start>Control Panel>System and double click.
Your printer should be listed. Select it and right click. On the drop down Menu, select
Properties.
In the new window click on the Ports tab. On the list should be your printer , the box
should be ticked, [ and if you are sharing the printer it says 'USB Virtual Printer port to
'your printer']
Under that are two more boxes-one says 'enable bi-directional support' - if not Tick it.
At the bottom Tick 'Apply' and close the window.
Failing that, all printers have a self-test facility when it does not matter if it is connected
to a computer or not. If that doesn't work, your printer is broke!
Mar 08, 2014 | Kodak Office Equipment & Supplies
ERROR: undefinedOFFENDING COMMAND: $mHa' m-F0, 1L4'STACK:
Not much info here. If this is an error message that prints out when sending a print job from your computer, try replacing the ethernet cable.
Jul 26, 2013 | Konica Minolta bizhub C450P Laser Printer
Can I connect canoscan 4400f using ethernet cable
i believe is not possible to connect to a router. printers ar designed to be connected to computers via ethernet cables and bluetooth when both devices are bluetooth enabled.(must have a wifi bluetooth ethernet card installed or usb bluetooth installed via usb). is you want to have the printer to be used bye more than one computer at home or office. you must set up each computer to the printer as well.. in control panel look for printers.then set up the conections.if computer 1 is printing a document. computer 2 will have to wait. when done. then will print work for computer 2.
Dec 18, 2012 | Canon CanoScan 4400f MultiFunction Color...
How do I connect my Action tec router V1000H to other computers to be able to print to ne printer. Iam running widnows 7
1)make sure that the printer is capable to be a network printer.
2) make sure that your able to print with main computer on the network.
3) make sure that the printer was able to detect the network via wireless connection ( if the printer have wireless capability) ( if not then it should be connected with a ETHERNET cable directly to your router)
4) make sure that the other computer already have the driver of the printer.
try using this first and if this will not work try sending me a message so that i can give you some more steps.
(ramiroreulin@gmail.com)
Apr 10, 2011 | Actiontec (5GE583000-01) Router
Want to print text messages from cell phone
Try sending any test messages to your email address using your cellphone. Then you can print anything using the email's Print operation. The more expensive alternative is to buy the cellphone's cable-to-USB for your model cellphone.
If your phone has bluetooth, send the text to your computer via bluetooth, then use your printer to print them, if you have a bluetooth enabled printer just send them straight to that, or if you don't have bluetooth at all, use a usb cable to connect to your computer.
To access the phone's SMS messages, just click the SMS entry on the left side of the PhoneView window. You can copy individual messages, Command-click to copy several messages (helpful when you want to copy just those messages that are part of a particular conversation), or copy all messages by selecting one message, pressing Command-A to select them all, and clicking the Copy From mobile phone button at the top of the window.
Nov 24, 2010 | Computers & Internet
Keep getting the error message "Printer not responding".
How are you connecting the printer to the computer? (USB, parallel, ethernet) Make sure there are no error messages/lights blinking and that the unit is on.
If you are using an USB cable, try a new cable. Also try a direct connection if you have a USB hub or print server in use. Make sure the USB ports are active (not disabled for power saving or security). Test the port with a known working device.
If you are using the parallel cable, make sure it is properly secured. Also try a new cable. Again try a direct connection instead of a print server.
If you are using an ethernet connection, again try a new cable. Check if your firewall is blocking communication with the printer. (Test this by temporarily turning off the firewall. If it starts working, make the printer a trusted part of the network. With some firewalls, you may need to unblock communication for both incoming and outgoing communication with the printer.)
I hope this helps.
Oct 18, 2010 | Konica Minolta Magicolor 5450 Printer
Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Jul 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
Zebra TLp 2844 (printer not connected error message )
Go to Control Panel, Administrative Tools (in Clasic view), and double click on Services. Scroll down and right-click on "Print Spooler". Start (or Restart) it and your printers will reappear in the "Printers and Faxes" window, and the spooler will try to send jobs to the printers again.
If you check the Properties of the Print Spooler, on the Recovery tab, you can set it to "Restart the Service". I set mine to Restart on the First Failure and Second Failure, and Take No Action on the Third Failure, in case something really needs attention.
Jun 23, 2008 | Zebra Eltron TLP 2844 Thermal Label...
52 people viewed this question
k24674
jasbo
jasbo
