Question about Indesit WA 115 Front Load Washer
Hey! My indesit wixxl106 washer won't do anything
When I press the ON button the green led of the "bubbles-type of washing" 4h button is on,then I press the start button, but nothing happens.. It all started after I opened the door in the last wash when the machine had stopped and thought it was over. The clothes were not leaking water,just a bit wet as they are normally at the end of the wash, but they were smelling bad and the softener was still in it's case. I have unpugged the machine from the power couple of times, opened and closed the door, but still nothing happens. Could anyone help me? I would prefer to avoid calling an expert and fix it myself.. Thanks a lot in advance !
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
jason0110
  • 66 Answers
SOURCE: Indesit WIXXL146 washing machine will not turn on
sounds like interlock or pcb try lock first as this is cheap to replace regards jason
Posted on Jun 15, 2008
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Posted on Oct 15, 2009
SOURCE: My Indesit Moon 1400 has stopped working. Shortly
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Posted on Apr 23, 2010
Indestit washing machine model iwme 126 is stuck on 4h does my one know how to restet the machine or fix this?
Try pressing and holding the power button until it flashes then turn off and turn on again the light will flash again and then reset the machine.
Not sure if this will work on this model but has worked on two Indesit machines I have had (both different models)
Apr 18, 2015 | Washing Machines
Ge washer tl1103pbwn
The washer uses a green light, which is the "Start" button, to indicate problems, and the flash pattern is a code to the type of problem. Two flashes means the washer's drain pump must be cleaned. Clumpy or poor-quality detergents can clog the drain pump. The user can attempt to fix the pump, but, If the problem continues, he must contact the GE customericon1.png service line for professional service.
Read more: http://www.ehow.com/how_12129638_troubleshoot-ge-washing-machine-green-light-flashing-two-times.html#ixzz2qLdypTQ0
Jan 13, 2014 | Washing Machines
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
The letters DENO is chown on the display
Hello & Welcome to FixYa
The washer is in DEMO Mode and to deactivate it there are three ways depending on the age of unit:
1. Press Start/Cancel button untill all console LEDs illuminate....Then press both Start/Cancel and On/Off buttons together until d OFF appears on display.
2. Press the CANCEL button to cancel the DEMO mode.
3. Press the On/Off and Start/Cancel button together with the top left button option until the d Off appears
Please get back to me if you have any other questions.
Kevin
Jan 26, 2011 | Indesit WA 125 Front Load Washer
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Re Instructions manual
You can download instruction manuals for Indesit products from the http://www.indesitservice.co.uk/hs/pages/manual/manualSearch.do
page on Indesit's service website.
Grame
Apr 11, 2008 | Indesit W 123 Front Load Washer
Indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Jan 25, 2008 | Indesit WA 115 Front Load Washer
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Indesit WA 115 Front Load Washer Logo
65 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
