Question about Kitchen Appliances - Others
Fuse F1 is blown
I have replased Fuse F1 but as soon as i put on the power suply the fuse blowes. What can be the problem?
    Problem Solver:
  • 5 Answers
You don't give any information about the make & model of the machine, but if the fuse keeps blowing, it's probably due to a short circuit somewhere in the machine. It could be as simple as a cut in part of the wiring, allowing the copper cable to touch another metal part, or it could be the compressor or pump wiring shorted out. If you don't have the experience or equipment to isolate the short, your best bet is to call a service engineer.
Posted on Dec 05, 2013
Why does the fuse keep blowing on my cub cadet ltx 1050
A fuse blows because the circuit it provide power to has a shorted component or wire.
May 16, 2017 | Cars & Trucks
2006 ford five hundred burning fuse 48 as soon as it starts what could be causing this problem
Fuse # F1. 48 , location ? under hood fuse box ? 10 amp ? There are several thing's this fuse power's up ! Evap vent and purge solenoids , 4 O2 sensor heater circuits , A/C clutch relay , EGR motor . What transmission does it have CVT or 6 speed automatic . Powers the transmission control module . One of these is shorted to ground . Disconnect them all then put new fuse in an then connect one at a time till fuse blows . You find your problem circuit !
Dec 28, 2016 | Ford Cars & Trucks
Fuse is blown = need to replace, what type of fuse should I use
How to Change Treadmill Fuses ' LIVESTRONG.COM
www.livestrong.com > Sports and Fitness
Sep 29, 2015 - If the fuse on your treadmill has blown, it's time to replace it. ... Thetreadmill fuses are located inside the elevation motor. If you don't have the ...
Treadmill blowing fuse. ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Sep 1, 2014 - I have recently picked up a second hand treadmill with an issue (York Challenger ... If I unplug the motor from the control board it will not blow the fuse, and will give ... Not sure yet, but i'll replace the IGBT's/power mosfet (I still don't know whats ... Treadmill goes high speed then blows the fuse
Nov 25, 2015
Treadmill blows fuse as soon as it starts
Sep 29, 2015
treadmill motor controller problem?
Aug 25, 2012
Treadmill Controller - No power to motor
Feb 11, 2012
More results from forum.allaboutcircuits.com
Jan 20, 2016 | Exercise & Fitness
MY MAGNAVOX TV MODEL#30MF301B FUSE BLOWING UP AS SOON AS I PLUG IN
The power suply board has a severe short and will most likely need replacement. You can get replacement power boards fom www.tvcircuitboards.com
Feb 06, 2013 | Magnavox 32MF301B LCD TV
Fuse fo tail lights and tack,speedo don't work blows fuse as soon as its instaled
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and start tracking the wire from the power side of the circuit breaker or the blown fuse receiver, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jan 08, 2013 | 2001 Harley Davidson FLHTCUI Electra Glide...
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
I got an amp and as soon as i put the fuse in it blows even with the deck of all wiring is correct and i hear a thump from the subs when i put the fuse in, the subs work good on a diff amp
Sounds like the amp is blown. Is it the fuse at the amp that blows? or the one at your battery? disconnect the ground and power wires from the amp and check for continuity between the ground and power on the amp terminals. you should have no continuity, and if you do i would check for a shorted power supply mosfet. try disconnecting all speaker wires, rca's, and remote power and see if it still blows. If it does its a problem in the amp, probably blown mosfets.
Jun 30, 2009 | Car Audio & Video
Fuse still blown
Not the cord. There are 4 rectifiers (diodes) very close to the fuse. They are black with a stripe on one end. Most likely one of them has shorted. This is a common problem and if you know how to check them this will probably correct the issue.
Jul 05, 2008 | Televison & Video
Blown Fuse
It's drawing too much power. Maybe a short in an amp. Do you have any warranty left? Double check to make sure you have the right fuse. You might also try a slow blow fuse so  you can turn it off right away as soon as the fuse starts to glow to help in diagnosing.
Apr 23, 2008 | Harman Kardon HK 3370 Receiver
Kitchen Appliances - Others Logo
53 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
