Gateway NV53 Stuck in sleep mode
Power light is on various buttons work on the touch display but the laptop acts to be in sleep mode
SOURCE: Gateway laptop
you and your computer need to tite lohdra ok
i thanig your problem sovel
Posted on May 05, 2008
  • 36 Answers
SOURCE: Laptop stuck in sleep / hibernate mode??
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
Posted on May 19, 2008
Sameeraryan
  • 82 Answers
SOURCE: computer won't wake after sleep mode
there is no other solution part from this..............all brand follos the same procedure to come out of the sleep mode do not worry.................................Sameeraryan
Posted on Jan 14, 2009
frcs68
  • 1605 Answers
SOURCE: aspire one not turning back on after being in "sleep mode"
do you leave the laptop open or close when you are no using it?
if you leave it open, there is a switch at the top of the F keys, close to the LCD panel. press that button will turn on the the machine. if not, press the enter key twice and wait 10 sec. it should come up.
SOURCE: not turning back on after sleep mode
I had the same problem when I first bought my Acer Aspire One a few weeks ago. I searched the web for answers, but it didn't really seem like anyone had a solution. However, one guy on a forum or website said something that gave me an idea - he said something like: What's the problem? Just open it up, hit the power button, type your password, and it wakes up.
Well, that didn't seem helpful to me at the time that I read it, but after thinking about it, I had a hunch. I had not set up my netbook to have a password (yet). So I did. And it's been waking up from sleep mode like it should ever since!!!
Hopefully, if you're reading this, setting a password will work for you, too. If you don't know how to set a password, here goes... Start...Control Panel...User Accounts...Change an Account...[Pick your name.account]...then the option to create a password should come up. Let us know if this works for you!
Posted on Mar 15, 2009
Accidentally disabled touchpad
Typically on a Gateway computer there is a series of buttons on the top of the keyboard area, including a touchpad disable button. If that is not lit, press it until it lights up. Hope this helps! If not, check out this forum that might help you. Gateway nv53 touchpad does not works
Nov 08, 2014 | Acer LX.WZ902.004 - Gateway/nv75s23u...
Nv53 reboot issues
over a year with the same windows installed?, first of all and most cheap solution probably, make a backup of all your info (Pics, videos, docs), be sure of having your laptop drivers and format your laptop hdd, depending on your sistem install window 7 or windows xp (Titan ue, will do it for you), then the drivers, antivirus, malware protection and a firewall, if that doesnt work maybe a loose memory, try to run some memory tests to be sure (You can find some software on the net for this purpose), try to remove the hdd from the laptop and check for virus and malware on other machine with a good and actualized antivirus using a sata/ide/usb cable this are cheap and it shouldnt be hard to find one on some electronics or computer shop... if none of this works you should take it to a tecnician. good luck.
Jun 04, 2013 | Gateway Nv53 Nv5378u 15.6" Notebook Amd...
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
I want to paint the outside case and the touch pad, how do I remove these?
You have to completely disassemble the laptop
1) Remove ALL power to the Notebook.
2) Follow Anti-Static Precautions
3) Remove the Display Assembly.
Disassemble the Display Assembly, until you just have the Top Cover in your hand. (Gateway term = LCD Assembly Lid )
2) Remove the Ram Memory, Wireless Card, Harddrive, Optical Drive, Keyboard Cover, Keyboard, Palm Rest, and remove the motherboard.
{ Advise using an ESD wrist strap connected to a good ground source.
Average cost is around $3 to $6.
I connect, for example, to an unpainted surface, of the metal frame of an open, empty desktop computer case.
Use a mutli-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available, you can substitute with a clean egg carton. Label each egg holder.
SOME screws look VERY similar to other screws.
DO NOT mix them up! }
Gateway NV53 series of Notebook PC's - Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Where it states Gateway 400, with 400 being in blue;
go to the second line, and across. Click on NV53.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (NV53), it may take up to 30 seconds before the first page comes up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 18, 2011 | Gateway NV53A24u Laptop
Nv53 gateway laptop will not turn on, power brick is green,it just won't turn on
Please take out the battery then plug in your power strip, press and hold the power until it comes on.
Let me know if this works. What could be happening is the system went to sleep and was not responding to user input, so this would be a way of a hard reset for it. Let me know if it works or not, as the next step is a little invasive.
Sep 21, 2011 | Gateway NV5378u Notebook
Hey i need to purchase a gateway nv53 power board,cable,spring & button cover. I would like where can i purchase it & where to get it fixed.
From a quick search edrence89,
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=7564
http://cgi.ebay.com/GATEWAY-NV52-NV53-NV54-SERIES-POWER-BUTTON-BOARD-/110641410161?pt=LH_DefaultDomain_0
Pictorial disassembly of a Gateway NV53 series Notebook PC,
http://www.insidemylaptop.com/disassemble-gateway-nv-series-laptop-fix-power-jack/
[The Gateway NV5302u is part of the Gateway NV53 series, just as your NV5378u is.
The heading is for replacing the DC Power Jack, but I thought the pictorial guide may come in handy ]
Free Service Manual for the Gateway NV53 series of Notebook PC's,
Drop down to the second line in the first paragraph, and click on NV53.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
Regards,
joecoolvette
Jul 17, 2011 | Gateway NV5378u Notebook
After using my laptop(Gateway NV53) for about 5-10 minutes the screen will turn black or the screen will freeze. Non of the buttons works after this and the only way for me to reboot the laptop is to pull...
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power
setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc,
Jul 01, 2010 | Gateway NV5387u Notebook PC
My power up button lights up, and the buttons on the bottom on the keyboard lights up, but my screen will not light up! what is wronge with it?
try connecting an extenal monitor, if you got a display means LCD is busted, need fix from your computer manufacturer. but if no display on the external monitor, means videocard is busted
Jun 12, 2010 | Gateway MX3228 Notebook
I can not find the power button for off/on on the gateway nv53 laptop
The power button on the Gateway NV5378u laptop is in the hinge on the right side.
Jun 06, 2010 | Gateway NV5387u Notebook
Delay in Monitor display once the system goes in sleep mode
Instead of sleep mode, tyr hibernate. It is generally faster except the whole computer shuts down. When you power back up, you're exactly where you were. Mine takes about 30 seconds.
Feb 06, 2009 | Gateway Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
