Question about Razer Rz04-00700100-r3m1 Electra Essential Gaming And Music Headset
I don't know how to take the Razer Electra apart!
I have the same problem that this guy has on his headphone: http://www.fixya.com/support/t460553-apart But i have it on my Razer electra. I dont know how to take it apart rach the wires!
The cord got yanked and now my headphones dont portray any sound
try wiggling the cord as you play a constant sound through it. It is quite possible and probable that the cable inside the headphone got disconnected entirely (the copper wiring)
Jan 31, 2014 | Audio Players & Recorders
I cant move my razer naga mouse top and buttom
Try cleaning the lens with some Windex or any other cleaning spray. Not too much, you don't want liquids in the mouse.
May 20, 2012 | Razer Naga MMO USB Laser Gaming Mouse -...
My skull candy ink'd left bud broke apart,how to re-wire it.
The wires inside the cord have broken, Unfortunately there is really no easy way to fix it, they don't solder well and replacing the cord is the only option but this also may not be successful. Replacing the headphones is the only proper solution
Mar 01, 2012 | Skull Candy Audio Players & Recorders
Hi I bought Razer Mako speakers few days ago, and from the start i've got this problem... The speakers stop working (there's no sound) after few minutes (from 7 to 15) of playing, the same for different...
I had the same problem today. Don't know what caused it. But I turned off the Makos using the switch behind the subwoofer waited about a minute then turned them back on, problem solved.
Hope this helps you and others who encounter this problem.
Sep 07, 2010 | Razer Mako 2.1 Speakers
8985 360 conplete. I got a new charger & cleaner base. Unit chargers and full lights comes on. Cleaning cycle lights does not work or clean. This is third new base i tried. I think truble is razer. I...
the razor is warranted for 2 years if you want to contact Braun for replacement. You can try to tap the razor with the palm of your hand after taking off the shaver top and blades. Sometimes this will help dislodge anything that is keeping the shaver from making good contact inside razor.
Just don't beat it against anything hard.
Oct 29, 2009 | Braun 360° Complete 8985 Electric Shaver
Razer Barracuda sound problem (with temp. solution)
find new hardware wizard . microsoft uaa driver for high divinition audio
May 25, 2009 | Razer BARRACUDA AC-1GAMING SOUNDCARD 7.1...
Static in headphones
I get the same issue. I think its the headsets itself. I have no problem with any other headset but this one is just static.
Feb 18, 2008 | Razer BARRACUDA HP-1 8 CHANNEL GAMING...
No sound
Are the lights on the side on? If not try the little switch on the side of the in line remote, also they need to be plugged into the soundcard&USB.
Dec 25, 2007 | Razer Barracuda HP-1 Consumer Headphones
Razer Diamondback
under the big plastic slide of the mouse theres a screw you just need to take out .. then gently pop it open the bottom end and pull it back.. DON"T TRY TO PULL IT OPEN COMPLETELY.. there is a little hinge that holds the top 2 buttons in place. just pry open the lower end and gently pull back.
Oct 31, 2007 | Razer Diamondback
Razer Rz04-00700100-r3m1 Electra Essential Gaming And Music Headset Logo
41 people viewed this question
Top Razer Radio Communications Experts
 Grubhead
Grubhead
Clive
Clive
Ken B
Ken B
Are you a Razer Radio Communication Expert? Answer questions, earn points and help others
