Zanussi problems AL5 error on DES959
  • 37 Answers
Could be the water valve on washer is faulty, not opening,
sometimes forgotten, is the water tap is not turned on.
Check that the Inlet Hoses are connected properly.
Posted on Nov 19, 2013
My zanussi washer is coming up with error code 40 anyone no what it is
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
Dado
Aug 27, 2015 | Zanussi Washing Machines
Eh0 error message during operation
need manual or need to know if washer starts and when it stops as this can identifie the problem
Aug 12, 2012 | Zanussi Washing Machines
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi aqua pulse 6965 AL5 error
it may be the WMS is blocked, i get AL5 or AL6 at the start of the program. here is how i have fixed it the last couple of times. WMS is around £70 (in 2010) - i have that on mine every 4yrs or son - i change the WMS sometimes called the water management system or water softener. it located on the left of the machine.
the floor will get wet during this repair.
you need to turn off the power; turn off the water supply; to it take the top off remove the two screws at the back of the lid. then work your way around the left hand side removing the panel retaining screws. once that is off you can see a large blue plastic 'thing' this is the WMS that you need to replace.
to remove this you need to remove the screws around the inlet for the water, i think there are 5 or 6, some are revealed once cover plates are removed.
there are 5 or 6 retaining the WMS; the most important are the tow at the bottom toward the middle.
now gently prise off the WMS releasing the tabs and catches. do not pull it off as there are some connections still to be disconnected. As to lift the WSM at the bottom right, behind the WMS there are three pipes held on with spring clips, these need to be released. then the WMS should lift off.. replacing is the reverse of the above.
Jul 13, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi LS 14
for remove C8 error on zanussi LS14 you must press on/off and press cycle2 key and you get FAC press cycle2 key again 8 times and you get CFG enter on family of this paremeter pressing ifinity key go to parameter ALR and you get ALR= 1 change to ALR=0 AND FIX THE PROBLEM.
Feb 28, 2009 | Zanussi 29 in. LS14 Free-standing...
ZANUSSI ZWD1471S
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Apr 04, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
Zanussi aqua pulse de 6965
We have AL5 quite requlary. It seems to be related to the pressure of the water going into the machine. I think if it is too high this alarm can be tripped.
There are two main ways we rectify the problem:
1. switch off the inlet water supply. Disconnect the hose at the machine. Let any surplus water drain out (only a couple of spoonfuls). Reconnect and switch on water.
That sometimes resets a sensor inside that relates to the AL5.
2. If the above fails then we remove the panel where the inlet water hose connects to the machine (There are three screws). Then carefully left this panel away from the machine. It will not come right out as it is connected to various bits inside the machine but you can get some access inside. On the left hand side there is a pink pipe with a white stopper on the end. Remove the stopper and let an excess of water out (this might be as much as a cup full). Of course, this must be done with the machine switched off and un-plugged from the mains!! There are electrics inside.
Once the pink pipe is drained, put the stopper back on and reassemble and connect. 90% of the time this works fine.... but the problem does come back.
If it doesn't work after the second procedure has been done then try leaving it over night (with the water inlet switched off) and try again in the morning.
I have experimented with putting the inlet tap half on (i.e. to lessen the flow of water) and that seems to give us longer before the problem returns.
I checked on a site a while back which had suggested that Zanussi were aware of a design problem. Of course, unless cars, they have no recall policy. I have tried to ring them once or twice but have got nowhere. Its hard to tell at times whether you are ringing the right company let alone the right department!!
Aug 24, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
