Question about Radio Communications
I don't know how to open Razer electra
I have a Razwer Electra. The left side of the heads works ubt have no bass at all. I know that there is problem in the headset. My problem is i don't know how to take the Razer Electra apart.
SOURCE: how to take apart
I figured out how to remove the headphone clip without causing cosmetic damage to the headphone casing. Unfortunately for me, this was after I had scratched up the casing already. Anyway, to avoid the cosmetic damage, use some kind of plastic tool, like a plastic spoon. After pulling off the headphone cushion, you will see the aforementioned 4 slots. Carefully slip the handle end of the spoon underneath one of the slots(not through them), and apply gentle pressure toward the center of the speaker. Do this for each of the 4 slots, and the tabs should easily come loose. Hope that helps.As for figuring out how to get the headphone to work, I'm waiting for that solution myself. The right headphone is out, but the left one works, none of the wires are loose, so the damage must be from my nephew being careless with the headset cable, and probably tugging on it once too often. Don't let your 15 year olds use your headsets, if they tend to be clumsy :)
Posted on Jan 11, 2009
  • 2920 Answers
SOURCE: Heater Core Replacement for 1986 Buick Electra Park Ave
there is no easy way to change out a heater core...you have to take the bottom part of the dash loose and that takes some doing. once you get the bottom of the dash apart you will see the heater core.then you have to go under the hood and unhook both water lines that run to it, you should then be able to pull the heater core out and install the new one
Posted on Feb 09, 2009
SOURCE: How to change time on NEC Electra Elite IPK? I
You have to be on the root phone or "first phone".
To check various phones -Hit {feature} 4.
Should display 100= TEL 01. Once on the first phone then use {feature} 9 #.
Time will flash at top of display and can be adjusted.
If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: instuctions on Graco Contour Electra travel on how
The instructions are printed on out side of mattress board. Thanks
Posted on Apr 11, 2009
  • 123 Answers
SOURCE: my left side of this headset is not working
those wires are very fradgile and chaces are they have snapped inside the jacket
it happens mostly when you pull on the wire instead of the jack or the wire gets caught or stretched --is your jack fully inside the connecter? wiggle the wire and if it sound than it is the wire
Posted on Apr 22, 2009
My 2005 Harley Electra glide classic will not start. The fuel pump is not coming on when you turn the key and my bike will not crank?
there is a fuse on the left side side cover plate there is a fuse for the pump in the fuse block. Replace that and it should work.
Feb 15, 2015 | 2005 Harley Davidson FLHTCUI Electra Glide...
Where is the fuse box on my 91' electra glide
Hi Mont, 1992 and later Touring Models, fuel pump fuses and relays will be behind the right side panel, starter and ignition relays will be under the seat behind the battery, everything else will be behind the left side panel to access fuses pull back on the front two locking tabs and slide the cover up. Good luck and have nice day.
Dec 09, 2011 | 2003 Harley Davidson FLHT Electra Glide...
Location of ignition module on 2003 flhtcui
I'm not sure about that particular model as I have not worked on every model H-D made but usually the ignition module is at the front of the frame near the steering head on the left side.
Good Luck
Steve
Dec 14, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
Where is the battery location on a 2004 harley electra glide?
It's either behind the cover on the right hand side of the bike in front of the saddle bag or under the seat.
Nov 02, 2010 | 2004 Harley Davidson FLHTC - FLHTCI...
Where is drain
The Electra glide bikes usually have the oil tank on the bottom of the transmission. On the bottom of the oil, there are two drain plugs. The one in the center is the transmission drain. The one on the left side a bit forward is the oil drain.
Feb 28, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
I have a 2005 Electra Glide, and now when driving I hear this jiggling sound coming from my left hand side of the engine or some where in the bottom. Also I just got this green light blinking from the Rpm...
Sounds like a problem with your primary. Open the inspection cover and check the play on your chain. Cold, u should bet no more than a 5/8 inch deflection. Sounds like its too loose
Oct 24, 2009 | 2005 Harley Davidson FLHTC - FLHTCI...
Electra remote wont work with electra air con.
hi.you should have a sticker under the indoor unit head unit or on the side.
Jun 10, 2009 | Heating & Cooling
Color code 91 Buick Electra
Colors will be the same on both ends ( the switch and the mirrors . Unfortunately both left and right mirrors have the same wiring colors. Check electical flow through the mirror switch so as to know which wire controls left mirror and which wire controls right mirror, to insure you don't re-wire in error . Hope this helps
Apr 26, 2009 | 2004 GMC Yukon
Leaking
Dear Greengirl, I am have the same problem with my machine, and the problem is the o rings, they will need replaced. I have tried to source the o rings here in Dubai, but no joy. Dualit in the UK should have the spares. unfortunately they wont send them outside the UK.
Nov 02, 2007 | Dualit 84024 Espresso Machine
Briel artemis problem
I had the same problem.  Try putting a descaling tablet in hot water and in the tank.  Then try the rinse cycle over and over.  I did this a couple of times and it finally cleared up.  When it was clogged I could see the calcium built up on a little tube right inside, and now it is clear.
Oct 11, 2007 | Coffee Makers & Espresso Machines
Radio Communications Logo
1,014 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
