Question about Pelouze SP5 Digital Letter Scale
Postal scale won't display oz or g
OuE2 or ShoF appears
What does oue2 mean on the scale
Best Answer: Most digital scales have this message (OUTZ) and it can mean that your scale has been overloaded or has simply lost its calibration. If the scale was overloaded, then it is probably done for. Sometimes you can try recalibrating the scale using the manual to fix it. If the scale was delivered with this message, then I would call the manufacturer to have it replaced because it is considered DOA. If it has been some time since you purchased the scale though, and it was damaged from overloading, you may be out of luck, as overloading wouldn't be covered by warranty.
Scroll down a few sections on this page to section 4.
http://www.awscales.com/support/faqs
Oct 10, 2016 | Health & Beauty
Salter scales 9018s sv3r I changed battery display screen keeps showing L how do I remove this ?
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Jun 01, 2014 | Health & Beauty
Envelope postal scales by pelouse
go to a tobacco shop or a tobacco pipe shop"head shop",or ebay, Vintage Pocket Hand Held Postal Scale 0 2oz ,or here, Postal Scales Hand Held Scales , or, Items found similar to Hand held pocket postal scale keychain 100 grams... good luck,most staples will not sell them because they are commonly used to weigh drugs.
May 21, 2014 | RTO Pelouze Scale With Remote Display -...
The screen displays a code of 24C02 after new batteries are installed
spam,only 1 is needed,it was already answered,the code is what scale it is,it is nothing for you to worry about
Sep 23, 2013 | Salter Brecknell 311 Digital Postal Scale
Manual
You may download a copy of the manual here.
Mar 02, 2013 | Royal DS3 Exacta Electronic Postal Scale...
I have the royal ex3 digital scale and when i turn it on it just shows - - - - how do i fix it ?
I am having the same problem with my Royal ex3....changed the battery, but when I turn it on, all I get is - - - -
Anyone know what this means or how to fix it??
Jun 30, 2011 | Royal 17014c 10 lb Digital Postal Scale
What is the postal code for newport in london?
postal code is the a code it is say by survice centre
Feb 12, 2011 | Jobar International Idea Works Wireless...
Have a WeighMax postal scale..how to I cange from kg to pounds?
I had mine set to ozs for over a year and then it changed to kg. Couldn't reset it by hitting the button, so I removed the battery and then put it back in. It reset it to ozs.
Jan 15, 2011 | Precision Camera Weighmax Body Fat, Body...
Pelouze SP5 Digital Letter Scale Logo
Top Pelouze Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Pelouze Office Equipment and Supply Expert? Answer questions, earn points and help others
