My ar-m351n is jamming and will not stop rolling until after few min
    New Friend:
  • 167 Answers
Something could be blocking the sensor that controls paper feed. Try a good cleaning with a dry soft cloth. Blow out any dust and pay special attention to any bits of paper that may be hung up. If it continues you may have to take it in for repair/replacement.
Posted on Nov 18, 2013
Dryer starts for 10 sec and then stops, has an burn smell it runs great Although when it stops it won't restart until a few mins later. Then the same over again. Its a loud noise when going for 10 sec
It sounds like it's overheating.
Find and clean the filter.
The noise might be something caught between the drum and the mechanism. A bra underwire is common if your female (anonymous)?)
Check with a good torch...
If you rotate the drum and it squeaks it's something jammed or maybe the bearing.
Apr 20, 2016 | Dryers
How do i fix the error code f2-00 in AR-M351N copier
HI,
I assume you ran 25-02 when you changed the dev?, if not you will have to replace it again.
Check to make sure you have drive to the dev box, slide out dev box and rub your finger along mag roll and run it up, remove again and see if the dev has returned.
If it is a high mileage machine, you can get problems with the dev drive, the box itself or the toner sensor.
Cheers
Andy
Jan 24, 2015 | Sharp Toner Digital Copiers Ar M355 M351...
Reasons for paper jam in rh 2045
There are lots of reasons for paper jam...
... Take a look where it always happen.. There might some paper stuck on its path why its always Jam.. or the sensors are blind... get a paper.. roll it and blow it on the sensors... and sometimes broken parts..
Feb 09, 2013 | Sharp AR-5316 Advanced Digital Imager...
Sony DCR-SR62 screen rolls continuously
HAd the same
It's a flex wire connecting LCD with camcorder. got from the repair shop. did it by miself workes like new. it'very common in this kind of sony.
Aug 07, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Apr 01, 2009 | Sharp AR-275 Copier
Rolling lines
had a few with bad (go here) capacitors
good luck
please mark the post with a fixya
Feb 06, 2008 | Mitsubishi WS48511 48" Rear Projection...
Sharp Copier AR-C270 Code Problem
jam in the fuser unit, try simulation 14
and/ or possible bad sensor switch actuating as tho paper is stuck in the fuser. check that exit switch is not stuck open or bad. if jam elsewhere , fuser will not allow operation untill jam somwhere is removed.
Jan 30, 2008 | Sharp AR-160 Copier
22 people viewed this question
k24674
jasbo
jasbo
