Question about gunk" Hi Mileage Motor Flush Oil Treatment 32 Oz
How does gunk steer seal work - gunk" Hi Mileage Motor Flush Oil Treatment 32 Oz
My john deere 1070 loads up under a load and will stall. I changed fuel filter which was loaded with "gunk" and it ran ok for a while then is doing it again.
I am not sure what you are calling gunk but if this gunk is black it is engine oil. The tractor and the engine was built by Yanmar. The injection pump is lubricated with oil pressure from the engine. The seals in the pump will leak and engine oil will get in the fuel system and contaminate the diesel fuel and plug the fuel. Seals will have to be replaced in the injection pump to correct the gunk.
Nov 08, 2016 | John Deere Garden
Tip
Power steering leaks at seals
if or when your power steering pump starts leaking at the seals you can put a cap full of break fluid in with the power steering fluid it works,as long as you dont wait to long where the seals are completely wore out to bad
on Mar 11, 2010 | Chevrolet Chevy Cars & Trucks
WHERE IS THE DRAIN FOR MODEL 52CEC309351AA
Find the drain outlet and use a wet vacuum on the drain line to pull gunk clogging the drain line out. You may need to reclean on more periodic basis. Problems with drain line gunk buildup vary with location airborn contaminants. Your water leaking could also be not a drain problem, but an air leakage by the seals in the unit installation. If unit is not sealed properly, warm moist air can leak in past bad or missing seals and come in contact with cool surfaces and condense water out and leak out of unit.
Hope this helps
Oct 21, 2014 | Carrier Heating & Cooling
Crank shaft seal for vitz 1SZ ENGINE
Timing gear seal number Vitz, Platz 35-49-6
Feb 10, 2014 | Toyota Yaris Cars & Trucks
I have a leak in my steering gear on my 2003 chevy silverado
Steering Rack --you replace,they are not serviced for seal leaks
Steering Box--- I doubt you have --comes out & be worked on
The pitman nut & arm comes off & you replace the sector
shaft seal at the bottom
Dec 01, 2012 | Cars & Trucks
The drain seal in the bottom is ruffled all the way around so the water doesn't completely drain, black gunk collects around it. Isn't the seal supposed to be flat?
No,if by seal you mean hose or pipe then thats just they way it's made.It's unfortunate the gunk collects on it.perhaps flushing the machine through with a quality dishwasher cleaner will help with this.
Jun 04, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
My 1997 ford windstar power steering is leaking from the bottom of the steering column out of the rubber boot
replace the power steering rack or you can try (lucas power steering stopleak) alot of people will tell you this does not work but i found that if you refill with lucas brand power steering stop leak when low after a couple bottles it does work and will seal it up. I had a bad leak on mine (about two bottles of fluid a day after using lucas ..about 4 bottles it sealed up and i havnt had a problem in about two years.)
Jan 03, 2010 | Ford Windstar Cars & Trucks
Cleaning polar s725 watch/hrm
"Gunk" is definately not good in any watch. If it got in there because your watch is not properly sealed then you would need to clean it out and get it properly sealed up again. Proper lubrication is necessary, but "gunk" should not be in there.
Nov 18, 2009 | Polar S-725 Wrist Watch
I have mold on the rubber door seal
This is a comon problem In areas where miosture is high and the tempiture is warm. Try using bleach to clen it off with or you can use super clean to remove it from the rubber. Not touchingthe seal with your hands and clothes will help some to.
Aug 31, 2009 | LG WM-2277HW Front Load Washer
gunk" Hi Mileage Motor Flush Oil Treatment 32 Oz Logo
18 people viewed this question
Top Radiator Specialty Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Radiator Specialty Vehicle Part and Accessory Expert? Answer questions, earn points and help others
