Question about Dell Optiplex 755 Desktop Desktop Computer
Dvd RW not showing
My PC not showing DVD RW
    Novelist:
  • 178 Answers
Lot of these showing up? is it old or new? could be drivers not loaded or were damaged. look at control panel-devices- find the dvd device in list to see if it has a yellow triangle or red x over it. if it shows and is normal without a colored mark on it, it probably needs the drivers reloaded or repaired.
Posted on Apr 21, 2014
4 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: i did PC restore using Dell F11 reset tool / no dvd or cd recogni
Go to Dell's support site and to their driver page. Put your model number in the box for a search and a page with your drivers will appear, download the drivers for your model and do a re-install of them. download them to a temp folder and when they are downloaded, double click and they will self install, put off rebooting until you install them all.
Posted on Sep 04, 2009
  • 13 Answers
SOURCE: HL-DT-ST-DVDRW-GSA-121N DVD player will not record
the DVD is bad, or your firmware is not up to date, you also have to have a DVD Decoder in order to watch DVD's on a computer
Posted on Dec 09, 2009
  • 84 Answers
SOURCE: Bonjour, novice en PC mon lecteur DVD/CD-RW ne
because on dust try to replace to a new dvdrw
Posted on Mar 06, 2010
Is it possible that a cdrw/dvd of Toshiba Tecra M1 be replaced with a dvdrw?
Yes, it is possible to replace CD, DVD with DVD+RW on Tecra M1. Generally, it is possible to upgrade optical drive on almost all the laptops.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 27, 2011 | Toshiba Tecra M1 Notebook
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
On acer aspire 5520g the dvd rw spins the dvd but bio's says its unplugged and it won't read the dvd's
Try downloading a driver from the net, Or install DVD software such as Roxio or Sonic Cine Player. Does it show in hardware as a CD Rom or DVD/RW ? If it shows as a CD the driver is the problem.
Apr 02, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire l100 dvd problem
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
Feb 14, 2009 | Acer Aspire L100 PC Desktop
Compac Presario V2000 DVD CD read problem
ok sir witch company your DVD - RW first telme ?
ok any one open dvd drive clean lenss with cottin net fit same dvd use the dvd & cd data check data cable. open carefully ok you don't know contact H/W Eng : if Any Problam My email id : uday_uday2004@rediffmail.com
Apr 02, 2008 | Computers & Internet
Writing to a DVD+RW disc
You need to use DVD software such as Nero that supports DVD-RW. from the app is where you would erase and so on
also make sure your blanks are +RW and not -RW
Jan 10, 2008 | Toshiba Satellite A75-S206 Notebook
Problem while burning blank DVD-RW
try to replace another blank dvd wr or update your burning software.
Dec 14, 2007 | Computers & Internet
Cannot read the min handy cam dvds
The disc needs to be finalized before you play it on other equipment. But to do this will render the disk unusable- If you intend to record over it in time, So it is best to copy the info across to the PC- burn that to a disk and finalize it then most other DVD players[Not all] will run it.
Aug 14, 2007 | Sony (1-796-388-13) DVD-RW Burner
Dell Optiplex 755 Desktop Desktop Computer  Logo
Alun Cox
