Question about Kaspersky Labs Computers & Internet
Active pin code - Kaspersky Labs Computers & Internet
Cinemanow activation code
  1. Set up the Blu-Ray player and connect it to the Internet with a wired or wireless connection.
  2. Check for, accept, and update the device's software if prompted. Instructions to do this should be found in the device's manual.
  3. Activate your Blu-Ray player on the CinemaNow website. Do this on the Internet from your computer.
    • Create an account.
    • Connect your Blu-Ray player to your account. There are two ways that this can be done.
a) Input the PIN number provided during the signup and activation process.
b) Input the PIN number provided on the application on your device, and then input the activation code into your device using the remote.
4. Select a movie and enjoy.
Create an account.
Jul 20, 2014 | Samsung Televison & Video
I want to knw hw i cn use my nokia 2700c security setting like wt is barring code and pin codes (and plz gives this two default codes )
PIN code is for simcard security the default is 12345...But if what you say is Locked code ,its the security of phone the default is 12345 ...about Barring code ,here is some tips...
Before you can activate these barring services you will need a barring code from your service provider. Call Barring can not be activated if Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
All Outgoing Calls
To Activate: * 333 * BARRING CODE # [SEND]
To Cancel: # 333 * BARRING CODE # [SEND]
To Check: * # 333 # [SEND]
All Incoming Calls
To Activate: * 353 * BARRING CODE # [SEND]
To Cancel: # 353 * BARRING CODE # [SEND]
To Check: * # 353 # [SEND]
All Outgoing Calls
To Activate: * 33 * BARRING CODE# [SEND]
To Cancel: # 33 * BARRING CODE # [SEND]
To Check: * # 33 # [SEND]
All Outgoing International Calls
To Activate: * 331 * BARRING CODE# [SEND]
To Cancel: # 331 * BARRING CODE # [SEND]
To Check: * # 331 # [SEND]
All Outgoing International Calls Except To Home Country
To Activate: * 332 * BARRING CODE# [SEND]
To Cancel: # 332 * BARRING CODE # [SEND]
To Check: * # 332 # [SEND]
All Incoming Calls
To Activate: * 35 * BARRING CODE # [SEND]
To Cancel: # 35 * BARRING CODE # [SEND]
To Check: * # 35 # [SEND]
All Incoming Calls When Outside Home Country
To Activate: * 351 * BARRING CODE # [SEND]
To Cancel: # 351 * BARRING CODE # [SEND]
To Check: * # 351 # [SEND]
Canceling All Call Barring # 330 * BARRING CODE # [SEND]
i hope it will help you...
Apr 13, 2011 | Nokia Classic 2700 Cell Phone
Hi, please how can i retrive my phone pin code.
The pin code is on the simcard. The phone has blocking code, if you activated this option. Try to call your mobile operator to reset your pin code or to activate another new sim card with the same number.
Apr 04, 2011 | Samsung Cell Phones
Get me a new security code of nokia 7210
The PUK code is not related to the handset. It is associated with your SIM card. When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked.
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
Mar 14, 2011 | Nokia 1100
Somebody put a pin on my gps and now i dont know the pin because somebody just gave it to me
This is an anti-theft feature. To overcome the requirement to key in the pin code, you must go to the exact location where the pin code was entered, and the GPS will activate without keying the pin code in.
It means you need to know this location or alternatively you have to contact that person to get the pin code from him.
Jan 19, 2011 | Garmin nuvi 1450 GPS Receiver
How can i activate my security keyguard? they are asking a pin number.
Type in your pin code and they will let u set your keypad security code..
But im not sure what are you asking. Where they ask you to type in your pin code?
Oct 07, 2010 | Cell Phones
How do I get a pin number for my h500 bluetooth?
the pin number is the code to activate the sim card to work with the phone!
pin and puk belong to sim card
the only codes requested by phone are "security code", "pin2" and unlock codes
dont forget to rate
Jun 17, 2010 | Cell Phones
Cell blocked
Securing your Shine
Secure your LG Shine and your account from thieves by locking your phone and your SIM card Losing a phone through accident or to a light-fingered thief is annoying, frustrating and potentially very costly, especially if the 'finder' uses your SIM card to make expensive calls. You can, however, lock both your phone and your SIM card with four-figure PIN numbers to prevent unauthorised use.
The first line of defence is to set a SIM card PIN. This means that whenever you turn on your handset you have to enter a PIN code before the SIM can be used. The default PIN code for your SIM is dependent upon your network; usually it will be found in a small booklet that came with the SIM card.
The PIN can be enabled, disabled or changed from the Security menu – but you only get three chances to enter it correctly. After those three, the SIM will get locked and can only be unlocked by entering the PUK (PIN Unlocking Key) which your network can give you. Enter the PUK incorrectly 10 times, and the SIM will be irrecoverably locked.
To activate a PIN code request, open the main menu by clicking on the scroll wheel. Click 9 to access the Settings menu and click 6 to enter the Security menu. The first item is PIN code request - click 1 or OK to open it. By default this will be set to off. To activate a PIN request, click 1; you'll now be prompted to enter the four-digit PIN. When you've done this, click OK, and if the pin was correct, you'll see the confirmation message 'Complete'.
To deactivate the PIN code request, you would simply select Off from the menu by pressing 2; you'll need to enter the PIN code whenever you change this setting.
PIN code request prevents another user from using your lost or stolen SIM card in their own phone. To lock your phone, and thus render it useless to a thief, you can activate Phone lock.
Two levels of handset locking are available. The first - called 'When power on' in the Phone lock menu - is to require an unlock code to be entered whenever the handset is switched on. This can be confusing and irritating when used together with the SIM PIN, so a second option is to only request the handset unlock code when the SIM card has been changed - called 'When SIM changed'. This means that if your phone is stolen, the thief can't use their own SIM card in it as the phone will need a PIN code to unlock.
To activate either option, go to the Security menu (clicking 9 for Settings and 6 for Security from the main menu) and click 2 to enter the Phone lock menu. Click 2 to activate When power on or 3 to activate When SIM changed. In either case you'll be prompted to enter the security code. By default this is 0000. Enter the code and click OK to confirm.
To change either code, go to the Security menu again (clicking 9 for Settings and 6 for Security from the main menu) and click 5 to enter the Change codes menu. To change the handset's security code, click 1 to select Security code, or to change the SIM PIN, click 2 to select PIN1 code. In either case you'll be prompted to enter the old code before entering the new code twice, clicking OK to confirm each time.
Jan 10, 2009 | LG Shine KE970 Cellular Phone
Computers & Internet Logo
Top Kaspersky Labs Computers & Internet Experts
Tony
Dave Harris
Dave Harris
Are you a Kaspersky Labs Computer and Internet Expert? Answer questions, earn points and help others
