Question about Water Heaters
How do i change the batteries on Valliant CalorMAtic 392f. i only have insructions Spanish
Its not obvious how to change them!
I have a valliant atmo gas water heater and no hot water just the red bulb flashing
Gas (natural or propane) water heaters require electrical power to make the igniter work. The most common source is two (2) D batteries. When the batteries become weak an visual alarm will be visible, such as a red blinking light. Try installing new batteries.
Oct 10, 2016 | Water Water Heaters
How do i reset the thermal cut off switch on a vaillent boiler?
Hi, what model Valliant and are there any fault codes showing?
Feb 21, 2015 | Water Water Heaters
How do I change language setting on Vaillant VRT 392f boiler remote control
here mate try this it worked for me.
Press left key
Scroll till page 15
Code will say 000 - should be 1000
Press right key once change first digit to 1
Press right key again
Will be on C1 in top right hand corner
Scroll through C pages till A1
Two A1 pages looking for one that says de..utch
Click right key once and change to d.. English
Aug 04, 2012 | Water Heaters
Does an Valliant Ecotec plus 831 have a flame supervision device.
yes it does via the ignition electrode. its called flame rectification
Jun 15, 2010 | Water Heaters
I cant get the pressure up on my valliant eco tec pro please give instructions
eiter you have a faulty filling loop or presure gauge,i asume you know how to put water in?
Oct 05, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
My dad has a valliant boiler VP4 ZE15 IT IS AROUND 3 YEARS OLD IT ISNOT IGNITING I HAVE TURNED PRESSURE UP AND HELD THE BUTTON IN FOR A MINUTE. i CANNOT FIND WHWERE THE RESET BUTTON IS TO TRY THIS PLEASE...
Turn the power off at the wall , wait 60 seconds and the boiler will automatically reset.
Modern boilers are complex re safety and the boiler will only start if the exhaust fan is running and is up to speed .
The vacuum caused by the fan trips a switch and allows ignition to continue
If the pilot light does not come on it does not warm up the thermocouple which turns on the main gas valve.
If you go to the Valliant website they will supply you with a user guide
Sep 28, 2009 | Water Heaters
Valliant turbomax manual
hi ian
most boiler manufacturers now days have downloadable manuals on there web sites.
just type in "vailant boilers" and flix through until you find the correct page. if they haven't a download you can request a copy on the "contact us" page .
i hope this has been some use
Jan 23, 2009 | Water Heaters
Water Heaters Logo
205 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
