Question about Philips MFD 6080, laser LFF6080
Printer error motor - Philips MFD 6080, laser LFF6080
When i try to print my hp pro laserjet paper gets jammed and an error 59.0a is displayed
59.X PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor's cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
If you ever need toner and any other supplies for your HP printer, please give me a call. Free shipping and less expensive. Damien @ iPrint Technologies - 818.700.7419
Aug 28, 2014 | Office Equipment & Supplies
Fan connector
motor error - ensure nothing stuck in fuser - remove from printer, try new print cartridge
A motor error occurred.
x = description 0-motor error
2-motor start-up error
3-motor rotation error
1. Turn the printer off, and then turn the printer back on.
2. Make sure that the fuser or toner cartridge does not hinder the movement of the
gears in the drive train.
3. Check the main motor cable to make sure that it is seated correctly.
4. If the error persists, replace the motor, and then replace the dc controller, if
necessary.
Oct 01, 2013 | HP LaserJet 5100 Printer
Erro 59.00
Sep 15, 2013 | HP LaserJet 4345mfp Printer
Error 59.0 A motor error
59.X PRINTER ERRORA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor's cable to ensure that it is seated properly. 4. If the error persists, replace the main motor
Jul 13, 2013 | HP LaserJet 5100 Printer
I have a new hp laserjet 4015x that keeps giving me an error code 59.00.
Thank you for contacting FixYa with your printer inquiry.
59.xx is usually associated with a main motor startup error. A main motor error occurred.
Actions:
  1. Power cycle the printer by turning the printer off and then back on. Listen for motors.
  2. Open the printers back panel and remove the fuser. Check for paper jams then reseat.
  3. Check the toner cartridge and make sure nothing is hindering movement in the gear train.
  4. Check the main motors cable to make sure it's seated properly.
  5. If the error persists then replace the main motor.
Parts Info: http://partsurfer.hp.com/Search.aspx?SearchText=CB511A See Motor Section.
RL1-1657-000CN - Main drive motor (M101) - Drives the tray 1 pickup roller, tray 2 pickup roller, and feed roller.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Aug 26, 2010 | HP Laserjet P4015x Printer
How to reseting hp laserjet printer ETB
59.XY
PRINTER ERROR
For help press
alternates with
59.XY
PRINTER ERROR
To continue
turn off then on
None A printer motor error has occurred.
X Description
0 motor error
1 motor startup error
2 motor rotation error
3 fuser motor startup error
4 fuser motor rotation error
5 print cartridge motor startup error
6 print cartridge motor rotation error
9 ETB motor startup error
A ETB motor rotation error
B developing disengaging motor
startup error
C developing disengaging motor
rotation error
Y Description
0 no color/black
1 cyan
2 magenta
3 yellow
1. Turn the printer off and then
back on.
2. This message might also
appear if the transfer unit is
missing or incorrectly
installed. Ensure that the
transfer unit is correctly
installed.
ETB motor error
1. Clean the ETB unit
intermediate connector, J36.
If the connector is damaged,
replace it.
2. Reconnect the connetors J38
for the ETB motor and J1111
on the DC controller PCB.
3. Replace the ETB motor.
4. Replace the DC controller
PCB. Calibrate the printer
after replacing the DC
controller.
Jun 25, 2010 | HP LaserJet 5550 Printer
How can i fix hp3600 59.Fo error
59.X PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Apr 21, 2010 | HP LaserJet 3600n Printer
How do i fix a 59.90 error?
Mar 19, 2010 | HP LaserJet 3600n Printer
My printer clj 2840 displayed error code 59.c0 when powered on. How do i resolve this?
This mean a main motor error occurred. X description: 0 = Motor error 1 = Motor start up error 2 = Motor rotation error
Oct 16, 2009 | HP LaserJet 2840 Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Philips MFD 6080, laser LFF6080 Logo
29 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
