Question about Philips HTS3400/37B System
Philips HTS3400/37B it was working fine i moved it to my living room and now it cuts off at the start. it will play for a min. then just cut right off different times.
If you have a screwdriver q tip and rubbing alcohol you can fix it. Take the screws out remove the cover and locate the laser. It looks like a small lens. Dip the q tip into the rubbing alcohol just get it damp not dripping. Clean the lens with the Q tip and then put it back together.
Posted on Mar 23, 2008
The DVD player will not read the DVD it says No Disc .
Posted on Apr 07, 2008
I had the same problem, "No Disc." I think that issue may be tied to the ribbon cable that connects the DVD head reader to the control board. Unplug and remove the cover. The ribbon cable is light blue and connects the reader head to the control board. Lift the black retaining sleeve surrounding the ribbon cable on the control board. Clean the contacts, reinsert, and push the black retainer into position to lock the cable in place. This fixed the "No Disc" problem on my unit.
Posted on Nov 06, 2010
Internet wont pick up in any other room but near the router , cuts out a lot , nothing wrong with line etc ethernet works fine
Some thing is blocking the radio signal, you need to move it around the room or move it into another room to make it work.
Mar 17, 2015 | Computers & Internet
Viore tv sound cuts out
Could be a failing power supply
Mar 12, 2014 | Televison & Video
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
My internet with my wireless card cuts out often
Update your drivers.
I used to have this card its sktechy.
If new driver doesnt fix it I would recommend selling it and using that money to buy a new one.
Apr 06, 2010 | Linksys (WMP54GS) 802.11g/b Wireless...
I have two ptac units, both want to run 5 or 6 mins. and cut off
Make sure there is nothing in front of the units, Chair, Couch ect, if you take the cover off the Units, you will see a little black Thermoster attached to the coil.
If the air bounces back off of something then it will cool that Thermoster and shut the unit down before the desired room temp is acualy reached.
Also make sure your Thermastat control knob is turned far enough to the right so that its asking for more cooling, Or desired temp.
Hope this helps.
Good Luck!
Oct 26, 2009 | GE Zoneline Deluxe Series Cooling &...
BMW Z3 ignition cut off?
you can test the coil by moving its location and see if it behaves the same way on a different cylinder ie. misfires, I was also going to suggest that you recheck the power connections to each coil
Mar 22, 2009 | 1998 BMW Z3 Roadster
Cuts in and out
I suspect a bad compressor run capacitor. Take the unit to a service facility & have the capacitor & overload protector replaced. The overload will be weakened by the repeated cycling.
Jul 14, 2007 | Danby DPAC8020 Air Conditioner
Philips HTS3400/37B System Logo
380 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
