Question about John Deere Garden
STARTED AND RAN ROUGH AND WONT START AGAIN... NO SPARK
REPLACED PLUG, COIL, POINTS AND NOT LUCK YET
  • 51 Answers
Drain gas completely from tank to ensure no water is in the tank, check for spark with spark tester, if no spark shows with spark tester, re check gap on coil, if points & condenser are present, sand down the gap between the points to ensure a proper connection. Make sure to change fuel filter with a high quality John Deere fuel filter and use fresh fuel... Fuel can "go bad" after 1-3 months, if the tractor is/ left outside chances are there is water in the tank.
Posted on Nov 18, 2013
Testimonial: "Thanks for the advice... and yet nothing is working... was stored inside and used all summer for mowing.... changed plugs... points and condenser, and coil... getting ready to check the air gap between flywheel and stator/??"
4 Suggested Answers
  • 69 Answers
SOURCE: JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
Posted on May 19, 2009
woobie dog
  • 1273 Answers
SOURCE: 1976 JD 214 lawn mower Kohler engine K321AQS
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
Posted on Jul 19, 2009
SOURCE: no spark at spark plug center of Coil
2000 ford escort ZX2. 4cyl . No spark at the spark plug. Wires are good.
Posted on Aug 29, 2009
I have a 1996 Oldsmobile cutlass supreme and it was running alittle rough but was running. It sounded like it was missing alittle bit. It stalled on me at a red light but started back up and ran good. The...
The first thing to check is the ignition timing then the spark plug gaps. There are specific settings/size for the above and must be correct for the car to run smoothly.
May 08, 2017 | 1996 Oldsmobile Cutlass Supreme Coupe
Wont Start - No Spark
Older VW's and Audi's are notarious for this type of behavior. You actaully need a Vag or good diagnostic tester to tell you which plugs are mis-firing. You will need to replace a coil-pac or two. VW's issued a recall notice about 3 months ago about this issue and intends to re-imburse owners on certain models and years for coil-pac repalcement. After market coil-pacs should cost less than $50.00 each. Hope this helps.
Jul 05, 2010 | 2001 Volkswagen Passat
I have an 1989 ford Bronco II. We had the fuel pump replaced as well as the fuel lines. I started a few times but then stopped, wont start again. It turns over but wont fire. Could this be spark plugs or...
Well take a plug lead off any plug and the plug and put plug in lead and rest it on the engine with the thread resting on the metal block and then spin it over if a good blue spark then coil etc is all ok BUT if no spark then the coil could be faulty or condencer OR points need cleaning and regaping to 12thou
when all in good order start and test run .
Let me know how you get on Ron
Oct 15, 2009 | 1989 Ford Bronco
1974 Volvo Penta 280 won't start...no spark at coil
When you say no spark, do you mean from the main coil wire or do you know if the coil is getting fire on the plus lead? Check your negative lead to see if it became ungrounded. I think you meant the condenser was eliminated, but if you had a resistor the new kit may have been 6 volt and without the resistor its 12 volt.
Jul 05, 2009 | Boating
Wont start getting weak orange spark
Hi, Kinwin and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test, your battery may show 12.5 volts but has little or zero amps and must be replaced.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or CDI or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
No Fire solved Thanks Everyone
How to diagnose no spark situation on motorcycle
Honda SHADOW VT1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Mar 30, 2017 | 2002 Honda VT 1100 C2 Shadow Sabre
1990 ford ranger 2.3L running rough at idle and while driving
Hi check all the fuse. fi the fuse are ok . remove the coil pack and reverce if the cly missifire change replace the coil if not chage replace the electronic comtrol module ok.
Apr 20, 2009 | 1990 Ford Ranger SuperCab
Engine runs rough. Engine light on.
Try checking the spark plug, and the spark wires, if that doesnt clear things up then try replacing the roter under the distributor cap and check the cap for any corrosen
Mar 25, 2009 | 2003 Chevrolet Cavalier
Car wont start or if started runs poorly 98 ford taurus 3.0
check the fuel pressure or sounds like mass airflow metter itself
Feb 28, 2009 | 1998 Ford Taurus
No spark
What about battery and alternator (serpentine belt).
Dec 05, 2008 | 1992 Mazda MX-3
Garden Logo
315 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
