Computer tutorial laptop cant read my sony dsc-650 connected by cable
  • 27,725 Answers
What ??? is this a desktop or laptop ?
Do you mean you cant see yout laptop screen ?
The display on your laptop is the interface through which you interact with and control your computer.
If it is not working, your laptop will become virtually impossible to use.
A laptop is a computer, and like all computers is subject to both hardware and software problems that may affect the display.
Before taking your laptop in for repair or getting rid of it, you should first check the display yourself to see if it needs to be replaced.
Check the laptop's battery and power cord.
If the laptop is out of power, the display will not work.
This usually happens if the power cord is unplugged and you were unknowingly running your laptop on battery power.
Check to make sure the power cord is plugged in and that the laptop has power.
Many laptops also turn off the display if it is being powered by its battery after a period of nonuse. Touching any key will usually turn the display back on if the battery is not drained.
Restart your computer. If a software program is stuck or malfunctioning, it may cause your display to stop functioning.
Press and hold the "Power" button on your laptop to reboot your computer.
If the problem was a malfunctioning program, the display will turn on after the computer restarts.
Check the brightness level of the display.
If the level is too low, the screen will appear dark.
The brightness controls are usually located on two function keys, such as "F9" and "F10." Look for sun or light icons on the keys.
Press the key with the larger icon to increase the brightness level.
Alternatively, on some laptops hold the "Fn" key while simultaneously pressing the "Up Arrow" key to increase the screen brightness.
Check the display closed switch.
Many laptops have a small button that senses when the LCD screen is closed and puts the laptop in sleep or hibernation mode.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
If the switch gets clogged with dirt, it may get stuck in the closed position.
This will result in dark display even when the lid is open.
The switch is usually located near the hinges of the lid. Spray the switch with a can of compressed air to loosen the dirt so that it will resume its normal operation.
Plug an external monitor into your laptop.
If the problem is not software related, the external monitor will display the laptop's screen.
Connect the monitor by plugging the cable into the VGA, HDMI or DVI port on the laptop.
Press and hold the "Fn" key while simultaneously pressing the "F8" key.
The video output will be directed to the external monitor if there is a hardware problem.
Posted on Nov 18, 2013
I USE TO HAVE A LAPTOP AND WAS ABLE TO DOWNLOAD MY PICTURES WITHOUT PROBLEMS. NOW I AM BACK USING A TABLE TOP COMPUTER, I HAVE THIS OTHER CABLE WITH A YELLOW & WHITE MALE IN-PUT AND THE OTHER END FITS...
Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer.
You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number..
319698101 .... CODE (USB 5P) CONNECTION
Thanks.
Jun 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
I got sony cybershot dsc p 200 model digital camera. But it is not supported as web cam . Please give suggestions to set up the camera as web cam
Many digital cameras support streaming video over the USB connection, to use as a webcam. Unfortunately Sony cameras do not do this; I am confident of this, because they offer a tutorial describing how to make an analogue connection from your camera to your computer, for use as a webcam! (I feel this is a poor solution because few computers have an analogue video-in connection, and not all cameras have a video-out. They would not offer this solution if the USB streaming was possible.)
I'm sorry to tell you that unless you are really lucky and are able to follow Sony's tutorial, your best bet is to buy a webcam and forget using your camera. A whole webcam could easily be cheaper than the cable that Sony suggest you use...
Jan 19, 2011 | Sony Cyber-Shot DSC-P200 Digital Camera
Display reads usb mode mass storage usb memory stick what does this mean?
it means that your camera is set to have the memorystick detected when connected to a computer. ( camera have options to have memorystick or internal memory detected by computer)
Sep 10, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
How to put videos in the computer with Sony DSC-T90 digital camera?
Hello the Abigail,
You just have to connect your camera using to the USB port of the computer using the usb cable. Once the computer detected the camera, right click your windows Start button and choose Explore. The windows explorer window will open. On the left panel, look for the local drive letter associated with the camera and click on it to show the contents of the camera to the right. The file of the video should be inside the folders to just double click on them to find it. Once found, you just have to right click on the file, choose Copy, then paste it on your computer's local drive.
Should you need further assistance, please let me know.
Jun 14, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Sony CyberShot DSC-S650 usb cable won't work
hi!we have read your problem.please dont worry, please connect your cam to the computer via usb port in switched on condtion .if the problem persists then try to connect it to diferent usb ports available in your desktop.every problem has a solution.hope your problem is tackled.have a nice day!!!
May 22, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Using digital camera as a webcam
I want use to my sony dsc w80 camera to web com but I dont know please tell me
Apr 03, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
How do use Sony DSC-H5 as a webcam?
pls see this page for detailed tutorial for ur camera and pls rate me FIXYA for this info if u like
http://esupport.sony.com/US/perl/model-tutorials.pl?mdl=DSCH5
Mar 05, 2009 | Sony Cyber-shot® DSC-H5/B Digital Camera
Format Error in Sony DSC-650
Please try with new memory stick. If it does not help please claim for an in warranty repair. If you need more info please advice.
Apr 12, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
