What means something not rigth - Computers & Internet
I want to change my steering wheel from the left side to rigth of car to drive from the rigth
If they made a right hand drive model you would need to get the front clip, steering, harnesses, dash and interior for it. Then have a body shop remove the front of your van and install the front from the right hand drive. Literally everything from the steering wheel forward would have to be removed in order to make it work. You would be looking a tens of thousands of dollars to make this happen.
Feb 20, 2015 | 2004 Chrysler Town & Country
Tip
Error 5C00 Canon ip 4600-4700
5C00 means you need to replace the purge unit,the purge unit is blocked or skipped.Try to unzip the printer and try to replace the purge unit,the purge unit is on the rigth of the printer.
on Apr 05, 2011 | Office Equipment & Supplies
Disconnected rear window defogger...car won't start 1994 geo metro
ops
i think you mean, I disconnected , rigth?
and the wire hit ground and the switch was one the fuse will blow.
its a huge fuse, and may take out others. up stream.
the car has fuses under dash (cab) and under hood, one is blown.
Aug 11, 2013 | 1995 Geo Prizm
Rigth mirror doesn't work
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 09, 2012 | 2005 BMW 325i Automatic
Inspiron 1300 i lost sound
if you are using vista or windows 7 it you may want to check what device is selected under sound properties, rigth click the icon of the volume then select playback option then if headphone is the ont that has a green check means defualt device ,try to select the other device for speaker to make default then try to play it again, if it will not resolve the issue it means u have to replace the speaker already.,
Jul 14, 2010 | Dell Inspiron 1300 Notebook
E000 System Error
you need to go into service mode and reset the error code
Jun 03, 2009 | Canon imageRUNNER 2000 Copier
Photon Digital Scorecard - Golf
Press player button long time, then select with right hole button time mode (12hr or 24hr).
Press player button to select hour and then press rigth hole button to select rigth hour.
Press player button to select mn and press right hole button to select rigth mn.
When tthe clock is right time, press a last time the player button.
Mar 18, 2009 | Sport & Outdoor - Others
HOW TO FORMAT/FLASH NOKIA N-GAGE?
HOW TO FORMAT A NOKIA N-GAGE
Feb 18, 2009 | Nokia N-Gage Console
Hi!
TRY THIS
access service mode .by depressing STOP- 00 --STOP- 0 -1
and than select counter, select trouble count and scroll untel you see what that cod means .
get back to me if you need more help
Oct 15, 2008 | Office Equipment & Supplies
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
