Question about Refrigerators
LG grp267ftg refrigerator stop open doors sound
Hello. I have the LG grp267ftg refrigerator. Is it possible to stop the beep sounds when the doors are open?
  • 54 Answers
SOURCE: GSS25 side by side refrigerator stopped freezing first and now refrigerator part doesn't stay cold. sounds like a fan is running but when I open the door the fan or whatever is running stops
Is there frost on the back panel in the freezer, If so change the defrost heater. If not is there anything running?
Posted on Jul 03, 2008
SOURCE: BEEPING NOISE
in the back of the fridge there is a panel. Remove the cover plate. Look for the buzzer and remove it. This will cancel the annoying beeping noise.
Posted on May 05, 2009
MNTECH
  • 1543 Answers
SOURCE: inside of door when you open lg refrigerator is very hot
I suspect you are talking about the area between the doors. Refrigerators use a loop off the compressor to warm this area to prevent condensation from forming there. Older refrigerators sometimes used an electric heater there, but of course that increases energy consumption. You will notice that the area is much warmer when the compressor is running. All this is normal, and saving you energy.
Posted on May 26, 2009
erpaalai
  • 999 Answers
SOURCE: LG fridge/freezer rumbling/vibrating sound
Check your defrost components. The fan is hitting the frost buildup and will shut off when the door is opened so as to not circulate the warm air. The heater or the timer is not doing a proper defrost cycle.
Eric
Posted on Jun 24, 2009
Mark335
SOURCE: door alarm keeps sounding even though doors aren't ajar
The problem is the doorswitch of the freezer door. The door 'bump' which has to push in the swich doesn't push it in far enough. You can try and hold the switch an dpush it in with your finger and see if the sound continues. You can try to adjust the door, but easier is to glue or tape something to the door 'bump' so it pushes the switch further in. Hope this was the issue.
Posted on Feb 10, 2010
How do I fix a buzzing sound in my fridge?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Apr 09, 2015 | Refrigerators
Smeg refrigirator keeps beeping without stop
Mar 09, 2015 | Smeg Refrigerators
Keeps beeping without stopping
How do I get my refrigerator to stop beeping
Sep 10, 2014 | Samsung RF4267HARS Stainless Steel French...
How to stop grp267ftg refrigerator sounds
This problem can be due to three reasons.
1.Your door of refrigerator is not properly close
2. Switch is not properly inserted properly
3. Current is not properly supply due to capacitor
In first case hold the door for a mint and see if sounds stop then adjust the door. May be you need a screw Gage to tight it. May be switch become loose so install a new plug. In third scenario open the back side of refrigerator and check the capacitor with meter.
Source:
Refrigerators With Most Modern Gates
Nov 18, 2013 | Refrigerators
LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
Apr 28, 2012 | LG Refrigerators
Door open alarm will not shut off
Try pressing the cut off button manually while the door is open. It sounds like the switch may be bad.
May 13, 2009 | LG LFC22740 Bottom Freezer French Door...
Want to dismantle the alarm sound.
I did this before and couldn't remember how. This works on our fridge which has a water dispenser and a bunch of buttons on the left door: Try holding the express freez and lock button for a few seconds. The beeping of the buttons should stop too. I tried countless live chats with the LG people and none of them could help me. I tried a bunch of combinations and found this one to work.
May 01, 2009 | LG LFC25770TT Bottom Freezer French Door...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
